Flooring trim solution.. cheap and easy! - Fiberglass RV
Old 08-09-2009, 10:36 PM   #1
Gina D.'s Avatar
West Coast USA
Anyone that has laid a new floor in their little fiberglass children knows:
1: They gotta be hip, cause they sure ain't square!
2. Finding a way to mount the trim can be a real pain.
Once again, wandering around a big box store, something caught my eye and I went "Yes! Thats it!
"It" is trim for fiberglass shower wall enclosures. It has a flange that extends way beyond the visible trim bit. My immediate thought was that that flange could be easily fastened to the sub floor with brads, and pushed and shaped to match the odd and uneven curves of the walls...minimizing the "gap" syndrome common with egg floor trim.
Sooo... in probably the worlds first Cart Before the Horse case that actually works.. I installed the trim BEFORE I laid the floor.
Old 08-09-2009, 10:40 PM   #2
Gina D.'s Avatar
West Coast USA
Now, this solution will only work with vinyl. I used the same "Novallis" wood plank peel and stick flooring that I did in my 13 footer, and it was a perfect fit. It tucked up into the trim gap like it was designed for it.
Add a little bright white caulk to the miters that never quite match, and run a small bead of the same to cover the big gaps at the corners... looks like it was meant to be!
I got this (And the flooring) at Lowes.
Old 08-10-2009, 02:32 AM   #3
Trailer: 17 ft Boler
Great timing! I am going to lay my flooring in a few days. I was just going to lay it like a rug and leave the trim till next summer, cuz I was too tired of doing fixing to deal with the trim. This looks like it is the perfect solution; I will use your idea!
Dawn S is offline   Reply With Quote
Old 08-10-2009, 06:18 AM   #4
Trailer: 1979 Trillium and 1989 Bigfoot (named 'Swanky')
Send a message via AIM to Donna R
LOOKS FABULOUS
Thank you for the idea.....and what a clever idea it is!
Look out awful little Trillium floor.
Donna R is offline   Reply With Quote
Old 08-10-2009, 07:39 AM   #5
Send a message via MSN to christineb
Off to Lowes! We've just got all the flooring and were about to start when I saw your pic. Thank you!! Great idea.
I want your underbunk cupboards too!
Christine
christineb is offline   Reply With Quote
Old 08-10-2009, 09:49 AM   #6
Robin G's Avatar
Trailer: 2007 Casita
Great solution for having a tidy, finished look! Thanks for posting Gina.
Old 08-10-2009, 10:04 AM   #7
Booker B.'s Avatar
Trailer: 1976 Trillium 13 ft
Thanks Gina, I have exactly that problem with the Allure flooring I put in - the caulking job I did looks just awful.
Old 08-10-2009, 11:21 AM   #8
Gina D.'s Avatar
West Coast USA
I do not think this will work with the Allure, as it is too thick, but they may make different sizes.
The Novallis stock is a perfect fit. If it was any thicker, it would be hard to install under the lip.
Standard tiles would be fine too, I think, or even low pile carpet.
Old 08-11-2009, 10:53 AM   #9
Gina..........help! We took off for Lowes in Eugene OR as soon as we read your email. Nobody had heard of the stuff you're using. I mean the vinyl stuff. We even took your picture with us and tried several other big stores with no luck. Does it have a name we can quote/order?
Thanks,
Christine
Attachment 22535
Old 08-11-2009, 05:25 PM   #10
Trailer: Fiber Stream
Talking
help!
Nobody had heard of the stuff you're using. [b]I mean the vinyl stuff.
It's ALL vinyl...
NOVALIS Flooring, Timber Series, [b]WD4018-94507: <strike>Gunstock</strike> Golden Oak
The [b]inside corner trim molding is more difficult to identify. Lowe's Website is no help. They don't sell it online; only in the store!
I can post a reference after I visit a store.
Old 08-11-2009, 05:52 PM   #11
Charlene Urso's Avatar
Trailer: 2008 21 ft Bigfoot
Gina, your floor is beautiful. What a great post. Thanks for sharing.
Charlene Urso is offline   Reply With Quote
Old 08-11-2009, 07:10 PM   #12
Gina D.'s Avatar
West Coast USA
its actually the Golden Oak... but sometimes its hard to tell the difference. The Gunstock is very dark. The natural is TOO light.
It should be located with all the peel and stick flooring tiles. At least, it is in every Lowes store I have been to.
I found the trim at the end of the aisle that had shower doors and other bathroom construction stuff. Sorry, I don't have a name or part #, but it is stored on end in 10 foot length. There are inside corner ones and flat panel seam ones as well. White and Almond colors.
Old 08-11-2009, 09:42 PM   #13
Talking
I found the trim at the end of the aisle that had shower doors and other bathroom construction stuff. [b]Sorry, I don't have a name or part #, but it is stored on end in 10 foot length. There are inside corner ones and flat panel seam ones as well. White and Almond colors.
The molding is called:
[b]Tileboard & FRP Trim
PVC FRP IS CNR WHT 8'
Model #79156
Item #8568
$2.28 ea.
Located on the Endcap of the Tileboard and Trim Molding Shelves.
Old 08-12-2009, 08:28 AM   #14
Thank you for going to that trouble. Let's hope I can find it now!
Christine
Model #79156
Item #8568
$2.28 ea.
A cheap and easy way to better towing! Scott H Towing, Hitching, Axles and Running Gear 20 11-03-2010 05:09 PM
Over easy ronsmith100 General Chat 10 08-20-2009 09:24 PM
Laminate flooring trim Robin H Problem Solving | Owners Helping Owners 14 07-14-2007 06:36 PM
Easy Bread Tom Trostel Camp Cooking, Food & Recipes 24 06-12-2006 04:37 PM
Hey folks...easy on me. Legacy Posts General Chat 9 08-16-2003 10:42 AM
