Forklift LP Tank - Fiberglass RV
Old 12-05-2011, 10:16 PM   #1
David Tilston's Avatar
Forklift LP Tank
I have been considering changing the LP mount on my trailer to accept a forklift tank. The tank would lay down across the front of the trailer with the 2 x 6V batteries in front of it. The 33.5# aluminum tank costs $210 in Calgary.
Why?
Well mostly because I think it would look cool. Not very rational, so lets start rationalizing.
- I can fill the tank at a gas station and pay by the litre, (gallon).
- It has a fuel gauge
- They are available in aluminum, (polished to a mirror, cool!)... I mean light.
- Sizes are 20#, 33.5#, and 43.5#. I hope to support all three with one bracket.
- Can get a liquid, (propane electrical generator?) and vapour.
- Can be used to refill 1# cylinders.
Manchester Tank: 1# Refillable Cylinders
- Slightly smaller diameter combined with tucking it in under the slope of the front of my Trillium 4500 would provide a more compact install then two 20# bottles.
Please feel free to point out the error of my ways.
Old 12-05-2011, 10:29 PM   #2
Sounds like a good plan actually! the 43.5# would give you more "profane" storage than two- 20 pounders and with the gauge you'd not risk running out.
However, I'd want to be sure it is legal and acceptable by your insurance company (and the motor vehicle licensing folks, too!) , just in case.....
I do not know if the "standard" 20 and 30 (etc) pound bottles are "crash tested" or how they are rated for use on highway (and on your BBQ!) but the forklift ones may well be a whole 'nother creature. (but the idea of a having a Polish - er, ahem, I mean polished alum one is very appealing!)
Old 12-05-2011, 11:56 PM   #3
Greybeard's Avatar
Name: Richard & Carolyn
Trailer: 2000 Casita SD 17'
Gabriola Island, BC
In some case/places, it may be illegal to carry a propane tank in a horizontal position.
I think it has something to do with it being propelled if the head gets taken off accidently
Greybeard is offline   Reply With Quote
Old 12-06-2011, 12:08 AM   #4
Propane tank
I hadn't thought of that....
There are the stories - mostly "urban legends", (I suspect) of a train wreck where a propane tank car got its end crunched and then lit off, becoming a rocket-propelled device that traveled for a few miles at high speed, setting of forest fires in the process.......
Train car loads of the stuff aside, I can see how it would be more dangerous to have the valve end facing outwards instead of on top.....
Old 12-06-2011, 12:32 AM   #5
Propane Rocket
Um...Propane is not at that high of a pressure. At -40 (F or C you pick) it can be carried in a bucket.
Thrust from combustion is ...um ... unlikely. This is rocket science after all.
Now a welding cylinder. Well, the shop video was really impressive!
It is DOT approved. What else could count? I don't think that they rate them by maximum allowable velocity. I'm no expert though.
I gotta tell you, they seem better built then the average BBQ tank.
Old 12-06-2011, 06:30 AM   #6
Raz
Raz's Avatar
Vermont
I knew a fellow who had a pickup that had been converted to run on propane. His tank sat in the back bed just behind the cab. He had no issues with state inspection as far as I know. Other than the cost, the only other consideration I can think of is tongue weight. Raz
Old 12-06-2011, 07:32 AM   #7
cpaharley2008's Avatar
I got me one of these, you can see the amount of fuel and they are RVIA certified.
Lite Cylinder LC-25-00 Propane Storage Tank, 25 Lb
Old 12-06-2011, 08:13 AM   #8
Raz
Raz's Avatar
Vermont
According to this site a fork lift cylinder is for dispensing liquid not gas.
Propane Cylinders - LP Gas Bottles
Jim, how often is the recertification on a fiberglass cylinder? Raz
Old 12-06-2011, 08:28 AM   #9
AFAIK, it's no different than metal ones. And propane is liquid, at least what you can see inside the f/g tanks , it turns to gas once exposed to air, I think that is what the regulator does in addition to keeping the pressure a constant.
Old 12-06-2011, 09:14 AM   #10
At Manchesters web site:
Manchester Tank: Forklift & Buffer Cylinders
I would like: 9315 - Aluminum 33.5# Liquid w/gauge - Fills through vapor opening
Old 12-06-2011, 10:10 AM   #11
It turn into a gas, i.e. boiling point, at some low temperature. I don't remember exactly what it is. It keeps it's liquid state by being under pressure. The regulator reduces the high the pressure to something in 4 psi range. Most propane regulators are two stage, meaning the first stage reduces the pressure so that the second stage will have an easier time maintaining the proper, as you said, constant pressure.
The biggest difference between a vertical and horizontal tank is where the gas is taken off. A horizontal tank has to have a tube that's along the top side of the tank when it's laying down to get the LP in its gas state. Orientation is critical in a horizontal tank.
Old 12-06-2011, 10:23 AM   #12
The boiling temp of propane is -40 (C or F, they are the same)
According to Wikipedia, (so don't quote me)
Propane requires just 1,220 kilopascals (177 psi) of pressure to keep it liquid at 37.8 C (100 F)
Should a tank experience a catastrophic failure, then the propane would boil until, through evaporative cooling, it dropped to -40. Then it would boil as quickly as it could get heat from its surrounding. Depending on conditions, this could take some time.
Old 12-06-2011, 05:56 PM   #13
Thanks for looking that up. My memory was better than I thought. -40 was what I remembered.
177 PSI would probably be high enough to rupture copper pipe. Again, I'm too lazy to look it.
Now that I think about it, copper pipe would probably handle 177 psi. We used copper pipe for 150 to 155 psi air lines.
Got over the lazy and looked it up. Lowest burst pressure was around 475 psi.
Old 12-06-2011, 07:39 PM   #14
Trailer: 1989 Bigfoot
It is very important to insure that the tank is sitting in the correct position if you rotate it in it's bracket you could get liquid ,the forklifts have bracket that holds them correctly. You can only use it for your l.p. system if it has a vapour outlet, you can't use liquid l.p. Your regulator can regulate vapour only ' if liquid gets in the line it will pass through and vapourize ,the l.p.pressure will go well past the max 14'' of w/c which is 1/2 lb . By the way all gas valves in R.V 's are rated for 1/2 lb
Hope this helps
ken h is offline   Reply With Quote
Istalling my FW tank Russell A General Chat 6 07-11-2011 11:18 PM
Added FW tank Russell A Modifications, Alterations and Updates 1 07-02-2011 07:22 PM
PROPANE TANK JIM DUNNE Problem Solving | Owners Helping Owners 5 05-17-2009 07:19 PM
LP Tank Clear Lyndon Laney Modifications, Alterations and Updates 4 04-05-2007 11:03 AM
Tank mountings Per Walthinsen Plumbing | Systems and Fixtures 12 03-08-2007 05:49 PM
