Old 10-17-2010, 09:57 PM   #1
BruceG's Avatar
Trailer: Scamp 13 ft
Found Scamp 7" LED Tail light replacement
I'm thrilled with my new 7" LED tail lights for my Scamp 13. They are an exact size replacement for the original wedding-cake 7" round lights. They are Doran 7" school bus LED stop, turn, tail lights from https://www.doranmfg.com/ledlighting_buslights.htm. The photo is the right side mounted on the Scamp. I had to drill new mounting holes and installed with 1" 8X32 stainless steel machine screws with a washer and nut on the inside. Of course I had to remove the benches to get to the wiring and mount the lights. On the left side I was able to mount the license plate bracket on the lower mounting screw. I still need to find a LED license plate light, but I wanted to wait and see how these mounted before I purchased one.
The back side has a closed-cell foam gasket, three wires soldered to the circuit board (including ground), and the circuit board is fully encased in plastic or resin of some sort.
I know some LED tail lights require an electronic flasher rather than the stock thermal flasher, but my Explorer has the factory towing package and separate fuses and wiring for the tail lights and they worked fine with no modification to the flasher.
They were a little more than I would have liked to have spent, but I am pleased with how the look and work.
I have also redone the side lights with LED fixtures and will soon replace the 12V interior and porch lights with LED bulb replacements..
Other mods to the camper are here - 1981 Scamp 13' Mods
- Bruce
BruceG is offline   Reply With Quote
Old 10-18-2010, 05:42 AM   #2
Kevin K's Avatar
Trailer: 1999 17' Casita SD 2nd owner
Hopkins,Minnesota
Also here https://www.empirechromeshop.com/p-1...bus-light.aspx
7 inch Round Transit LED Turn Signal Light, 31 Diode, Red
$25.20 here Trailer Parts Superstore - LED 7" Round Red Vehicle / Trailer Transit Light #STL-90RB
Old 10-18-2010, 10:06 AM   #3
Originally Posted by BruceG View Post
<cut> Of course I had to remove the benches to get to the wiring and mount the lights. <cut>
- Bruce
Bruce thanks for posting these as I have been looking LLED replacements for my wedding cake lights as well.
I am wondering though why you had to remove the benches to mount them? Can you not just use the wires that are already in place from the old lights?
Carol H is online now   Reply With Quote
Old 10-18-2010, 12:49 PM   #4
Raya's Avatar
Grote also makes 7" LEDs that will fit. I remember Con used them on his Boler. Grote makes school bus lighting and etc.)
Grote The First Name In Vehicle Safety Systems
With a quick perusal, I would guess these to be the ones (but I am not sure so double check before taking my word for it).
http://www.grote.com/product.php?product_number=53422
Old 10-18-2010, 02:46 PM   #5
Kevin K's Avatar
Hopkins,Minnesota
Best price I found was at etrailer.com for $13.95 each.
7" Round Transit Stop and Tail Light - Red Optronics Trailer Lights ST90RB
Old 10-18-2010, 08:46 PM   #6
BruceG's Avatar
There is no room at the back of the light unit for any wire connections because it is low profile and lays flat, so the connections must be made inside or pushed through whatever hole you have into the the body. It was easier to make all of the connections inside. Also the lights were mounted with machine screws with the nuts on the inside. I could not get behind the water take to do that. The benches on the Scamp come out very easily - just a few screws.
I guess I didn't search long enough for other vendors of the lights. It looks like I could have save a few $, but I'm still happy with these.
- Bruce
Old 10-18-2010, 08:54 PM   #7
BruceG's Avatar
Originally Posted by Kevin K View Post
Yes, but these use an 1157 bulb and I wanted LEDs. That's why I went with the Doran lights, even though they were more expensive.
- Bruce
Old 07-20-2012, 08:23 AM   #8
Trailer: Trillium 4500, Scamp 5th Wheel
Las Vegas, Nv.
Wallmart
Wallmart now carries the 7" round LED for $15 and the side marker lights for $5. Getting cheaper all the time. I about blinded myself when I hit the "try me" button LOL!
Steve
Old 07-20-2012, 08:48 PM   #9
Being seen (especially during daylight hours) is paramount! You'd think anyone following a big ole white "box" would notice when brakes are applied. That's NOT always the case. Do yourself a huge favor and swap out those old skool wedding cake lenses for the bright LEDs. There are no do-overs when it comes to an accident. Stay safe!
Double Yolk
1988 16' Scamp Deluxe
Old 07-20-2012, 10:58 PM   #10
Deb & Chuck's Avatar
Trailer: Fiberglass trailers
7" round LED Tail lights
I sell these for $25.99 each, any order over $50.00 are shipped free in the US. Look at FiberglassTravelTrailersRV.com
Chuck
Deb & Chuck
www.fiberglasstraveltrailersrv.com
Deb & Chuck is offline   Reply With Quote
Old 07-20-2012, 11:43 PM   #11
Trailer: 1972 Boler 13 ft
Princess Auto
Princess Auto have the 7 inch LED "Bus" lights right now for $19.99, bought a set...big difference.
Brad
Brad Judd is offline   Reply With Quote
Old 07-26-2012, 01:47 PM   #12
Trailer: Scamp 13 & TDI tugboat
Ohio
Has anybody tried an LED 1157 bulb replacement in the original fixture?
I just got done polishing the reflectors & lenses, and replaced all the screws w/ shiny new SS ones. Looks good & original, so I don't wanna throw that away, but I do like the low amp draw of the LED lights.
FJ40Jim is offline   Reply With Quote
Old 07-26-2012, 04:52 PM   #13
Originally Posted by FJ40Jim View Post
Has anybody tried an LED 1157 bulb replacement in the original fixture?.
I did but they were a disappointment compared to what I had already seen on other trailers that had the full replacement lights. The brightness was only around the very middle of the lens not balanced out over the whole lens so it really wasnt much of an improvement. The scamp lens on my trailer where actually in very good condition. Ended up biting the bullet and purchasing the full replacement lights posted above from Chuck and couldnt be happier with them. The cost of the full light replacement was actually about the same as what I paid at a local automotive shop for just the bulb replacement so I wouldnt waste your money on it.
Old 07-26-2012, 07:49 PM   #14
I picked up some LEDs from princess auto as well. I'm REALLY happy with the improvement over the stock lights. The stock lights look neat, but just didn't put out the light the LEDs do.
I used nuts and bolts on mine rather than screws. Overkill sure, but looks like it was it came that way.
Next task is to drill out the old rivets and scrape away the silicon that was put on to stop a leak around there. The leak was caused by the fact that some of the old rivets broke free. Part of owning an old trailer I guess.
nlife is offline   Reply With Quote
Tail light replacement for '77 scamp TomE Problem Solving -- Owners Helping Owners 11 09-11-2010 06:37 AM
Where to find 4.5" x 8.5" LED tail lights? Cory Lewis Problem Solving -- Owners Helping Owners 2 07-21-2009 09:52 AM
Tail light replacement Wayne Dirkson Problem Solving -- Owners Helping Owners 5 06-15-2009 07:43 AM
LED tail light on sale kentj Problem Solving -- Owners Helping Owners 2 06-28-2008 12:22 PM
LED Tail Light Princess Auto Alan P. Problem Solving -- Owners Helping Owners 16 02-13-2006 05:55 PM
the next 365 days.
Our Communities
» More about our Communities
Automotive Communities
Marine Communities
Close [X]
