front hitch tiki bar table mod***with Pictures jelousy alert* - Page 2 - Fiberglass RV
Old 06-12-2013, 11:14 AM   #15
Flygal's Avatar
I too have juggled 4 or 5 different table ideas and nothing really worked as I'd hoped. If someone was crafty they would have a second shelf below as a means to store plates or what not when at location. If it were lowered or had different leg heights it could be a great spot for say a cooler holder when in transit provided it doesn't weigh a ton to make the front too heavy
Originally Posted by Joy A View Post
Hey Brandi,
I like it. I have often thought I'd like a table up front. I now have the generator/propane box on the tongue but it's too high and not really convenient as it goes across the front of the Scamp. I like your angled setup.
Currently I use a folding aluminum table which can be used for other things. Over the years I've plotted different tables and means of mounting them and have never gone forward with any of my designs. Yours does give me a little more food for thought.
Great job
Flygal is offline   Reply With Quote
Old 06-12-2013, 01:48 PM   #16
That's a great idea. I have dual propane tanks but only have one connected to the trailer. Then at a campsite, I have a folding aluminum table I set near the tongue to put my portable grill on, which is then hooked up to the other propane tank. I always thought if I could have some sort of small platform on the trailer tongue I wouldn't need a folding table.
ThomasE is offline   Reply With Quote
Old 06-12-2013, 05:29 PM   #17
Marinab's Avatar
Trailer: 1978 Biggar / 2007 Toyota Tundra V8 2wd
I have seen the hot rod guys with something similar on the front of their bolers. On theirs' they have one arm that comes up and over the propane tanks with the table welded to it. They have drilled several holes in the bottom of the pipe so that it swings out to different positions and the pin goes in and locks it in place. When traveling, they just swing it back over the tanks and lock it into traveling mode with the same pin. Someday I might have time to get one made. The one thing that Brandy's has and the other guys don't is an umbrella holder. That is such a great idea. Keeps the food dry....
Life would be a million times better if there were Pinatas strategically placed throughout the day.
Marinab is offline   Reply With Quote
Old 06-12-2013, 07:26 PM   #18
Tonia's Avatar
Trailer: Scamp 13' (1982)
Wisconsin
Great idea!
Tonia is offline   Reply With Quote
Old 06-12-2013, 07:47 PM   #19
knighth001's Avatar
Trailer: 1984 Uhaul CT 13
I really like this idea. I've been trying to figure a better way to hook up my grill up front and this would be perfect. Thanks for sharing!
--Sean
1984 Uhaul CT 13
TV: 2011 Kia Sorento V6, 2001 Mazda Tribute V6
My U-haul Camper Blog
knighth001 is offline   Reply With Quote
Old 06-12-2013, 09:10 PM   #20
D Davis's Avatar
Trailer: u-haul ct13
Virginia
Brandy, Unique idea! I like the way you think! Thanks for sharing this design. Great job.
D Davis is offline   Reply With Quote
Old 06-12-2013, 09:57 PM   #21
Trailer: '77 Scamp
So darn clever. Thanks for sharing.
Otters is offline   Reply With Quote
Old 06-13-2013, 05:28 AM   #22
Pam Garlow's Avatar
Trailer: U-Haul 1985
Really great modification, Brandy!
Did you weld the holders onto the tongue?
Old 06-13-2013, 09:58 AM   #23
Trailer: 1984 UHaul CT13
Great job Brandy. Nice and practical mod.
keekers is offline   Reply With Quote
Old 06-13-2013, 11:14 AM   #24
Trailer: 2008 Casita 17 SD
So, when is cocktail time?
Nice addition...
Old 06-13-2013, 07:28 PM   #25
Trailer: '77 Scamp
Brandy, you said you picked it up at a thrift store. What do you think its intended purpose was? It's great when you can repurpose something and it works out so well.
Linda
Old 06-13-2013, 09:44 PM   #26
Flygal's Avatar
my friend did, so yes
Old 06-13-2013, 09:45 PM   #27
Flygal's Avatar
It appeared to be a stove grate for perhaps a park style bbq pit
Linda
Old 06-13-2013, 09:52 PM   #28
Flygal's Avatar
I like the grate material as rain won't pool on top. It is really sturdy and doesn't have the wiggle most little tables I have tried. There are two handles on top and since the weld is pretty tight they are needed to jimmy the grate up and off. The plus side to the welding overkill is this is something that will be on there for a long time. When I am driving two hitch pins keep it in place thou I doubt that thing would fall off
Another Scamp Table Mod UtahCamper Modifications, Alterations and Updates 5 05-04-2012 06:38 PM
More Escape 19 mod pictures (some one asked) Jack Allen Modifications, Alterations and Updates 5 06-03-2011 07:20 PM
Reversing Aid/Alert Mod Patrick M. Modifications, Alterations and Updates 8 07-30-2007 03:33 PM
Single Bar Weight Distribution Hitch Gina D. Towing, Hitching, Axles and Running Gear 33 03-19-2007 12:11 PM
Small Table Mod Legacy Posts Modifications, Alterations and Updates 2 08-18-2003 08:16 PM
