Fun with aluminum or a Shelf for our table - Fiberglass RV
Old 07-22-2003, 03:17 PM   #1
Our table wall was missing its beautiful(?) strap trim. We were going to trim it out with wood molding but then we saw a trillium brochure posted here that showed a small shelf in this spot. This is nice as it stays put even when the bed is made. I"ve also been looking at the redos on the vintage vacations website and stole their shelf idea. I went to the extra trouble of making mine a little crooked.
<img src=http://www.fiberglassrv.com/board/uploads/3f1da918445e6alum1.jpg/> <img src=http://www.fiberglassrv.com/board/uploads/3f1da943cd151alum2.jpg/> <img src=http://www.fiberglassrv.com/board/uploads/3f1da954b247calum3.jpg/> <img src=http://www.fiberglassrv.com/board/uploads/3f1da96530d56alumlast.jpg/>
Old 07-22-2003, 03:51 PM   #2
You are GOOD
:wave
Maggie O
That is a sweet little item. I wouldn't doubt that you milled the aluminum shelf in your own machine shop all by yourself.
In case you didn't do that and just bought the thing, how much was it and where exactly didja getit?
Me again
Old 07-22-2003, 04:40 PM   #3
Thanks, Tom. This item requires a long narrow piece of plywood (3/4" birch left over in this case & I rounded the front corners), aluminum table edge (Lowes $5.00) And aluminum stock. I got the upper edge stock at Lowes for $2.00 and the upright pieces were made out of wider heavier stock found at local hardware for $3.00. (I may have been the only person to ever buy aluminum there. The guy said," are you gonna buy a lot of that? 'cause if you are I'll have to restock.") I cut it with bolt cutters and used a grinder on the edges. The rest designed itself. The upper piece is a little too short. I didn't want to go back to the store so I decided I'd live with imperfection. It's attatched to the trailer with drywall screws. Hey I didn't put that smiley there. Are they just running wild now? The little side pieces are small strips of plywood, rounded bottom, aluminum edge.
Old 07-22-2003, 05:39 PM   #4
Love that shelf
Wow Maggie
I love that shelf, its fantastic. What a smart idea!
Nancy
Old 07-22-2003, 05:48 PM   #5
Nice shelf
Beautiful job, it looks 100 % professional. Looks way better than the one in my 1300 did.:thumb
Old 07-22-2003, 08:34 PM   #6
Thanks, it's so fun to hear comments right away.
Old 07-23-2003, 07:29 AM   #7
Ideas
My mind has been churning with ways I could use one of these in my Casita. I really like the looks of that.
You did a great job!
I see how the vertical pieces are held on at the bottom, but how are they attached to the top piece?
Old 07-23-2003, 10:17 AM   #8
I used my current favorite glue called plumbers goop. I had intended to screw them on but I switched horses in mid stream as I thought it looked better. The two ends are bolted with washer and lock nut.
Old 07-23-2003, 10:21 AM   #9
Thanks!
Old 07-23-2003, 05:50 PM   #10
Great project!
Thanks so much, Maggie! I am a lover of hot sauces, and all those tall-neck bottles keep falling out of the wire "shelves" Casita provides over the sink/stove area. But what if I designed a TALL shelf like yours and pop-rivetted it to the wall at the same place your shelf is fastened? The old wheels are turning and that's probably the smoke you're smelling! Thanks a bunch.
Old 07-23-2003, 08:02 PM   #11
Oooo a tall one...now where can I put one of those?
Aluminum trim for table Kevin M Problem Solving | Owners Helping Owners 25 08-08-2014 08:52 PM
Trillium 1300 - Information on shelf over dining table Booker B. Problem Solving | Owners Helping Owners 12 04-20-2008 09:54 PM
how to clean aluminum Maggie O. Care and Feeding of Molded Fiberglass Trailers 14 06-18-2006 07:30 AM
Aluminum Table Trim Legacy Posts Problem Solving | Owners Helping Owners 9 07-16-2003 09:02 AM
TV shelf and Table Fun.... Legacy Posts Modifications, Alterations and Updates 8 05-18-2003 09:11 PM
