Functioning Weep Holes - Fiberglass RV
Old 08-28-2014, 09:34 AM   #1
honda03842's Avatar
Name: Norm and Ginny
Conversations with CampyTime (Wendy) encouraged me to check my rear window weep holes. It's obvious that the weep holes in this window have never worked. They are effectively sealed by a plastic track in the bottom of the window frame.
I lifted the end of the plastic track a couple of inches with a flat bladed screw driver and clipped about an 1/8th of in inch wide piece off the weep side edge of the track for the distance of about an inch. I used a pair of wire cutters to do this. Pushing the track down I can now see light through the bottom of the track through the weep hole. Water flows easily. I did this on both ends.
After wetting this area for the flow test, I wiped it with a paper towel removing most of the accumulated dirt.
Thanks for the push Wendy.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 08-28-2014, 10:23 AM   #2
honda03842's Avatar
More functioning weep holes
I just spoke with Wendy and her bottom track has holes in it to allow water flow thru to the weep holes. Unfortunately they are not functioning. I can only assume dirt is trapped under her plastic strip with holes.
Ours works great now and I like that I can see thru the weep holes.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Leaking Burro front window & weep holes Colleen Rae Problem Solving | Owners Helping Owners 2 05-21-2014 06:35 PM
Does your Trillium weep? Raz Care and Feeding of Molded Fiberglass Trailers 16 10-22-2012 01:30 PM
Source for weep hole covers Pamela S. Problem Solving | Owners Helping Owners 14 05-04-2010 07:10 PM
Weep hole leaks on Casita? sandan Problem Solving | Owners Helping Owners 7 06-24-2009 08:16 PM
Fiber Stream Window Weep Hole Covers Frederick L. Simson Problem Solving | Owners Helping Owners 0 10-09-2007 10:27 PM
