Furrion 30 amp power inlet - Page 2 - Fiberglass RV
Old 05-15-2016, 06:49 AM   #15
Trailer: 13 ft Scamp
I like that post sleeve solution! How severely does the cord get folded to store in the sleeve? I am concerned at the stress that may be put on the wires by folding vs coiling. Thanks.
Darnelle is offline   Reply With Quote
Old 05-15-2016, 07:13 AM   #16
CampyTime's Avatar
Trailer: Scamp 13' Standard
I like this idea too Paul very much. Its creative! My only concern is because I have to mount pvc post on front of bumper face, that the 30 amp cord has quite a bit of travel to do before entering post, even covered with hose for protection. My spare tire eliminates a top of the bumper mount as there's no room. My stabs eliminate a below mount. I'm not sure if it will work without post under trailer like you have. Your 30 amp cord goes immediately into post, protecting all the way from road debris and elements. I'm looking at trailer now and I wanna get underneath to see how low a 4" pvc sewer pipe would ride. Probably better option for me than 5x5 fence post
Sent from my VS985 4G using Fiberglass RV mobile app
Old 05-15-2016, 01:29 PM   #17
Paul O.'s Avatar
Trailer: '04 Scamp 19D, Tacoma 4.0L 4door, SB
ex VT, now CO
The post being 5x5 in., and the diagonal about 7x7, the cord folding is not too severe. I fold it just enough to make it fit. What works to our advantage is that it is made of stranded wire. When the cord is stuffed into the compartment and then pulled out, it gets tangled and probably bent much worse.
Yes, Wendy, I forgot about the stabilizers that already take up the space under the bumper... The 4" pipe might be too small for the folded power cord. Some other solution might be needed for the 13' Scamps.
Old 05-18-2016, 06:57 AM   #18
rdickens's Avatar
Trailer: 2017 Scamp 16 Deluxe
I didn't use the metal junction box in the Marinco kit. It doesn't match up well with the curved sides of the Scamp.
If you think you need extra stiffening, I guess you might cut a ring out of very thin wood (Michael's?) or plastic .... something that would conform to the curved side of the Scamp.
Because the gray water tank & outlet are back there (and because I really don't want to break the epoxy seal on the wood floor), I would be very cautious about drilling through the floor. But maybe that is just me ... ??
YMMV.
Ray
Sent from my SCH-I545 using Fiberglass RV mobile app
rdickens is offline   Reply With Quote
power inlet installation question WDavidG Problem Solving | Owners Helping Owners 18 03-20-2016 10:55 AM
Today's Bigfoot project - 30 amp inlet trainjunkie Modifications, Alterations and Updates 2 04-28-2015 07:16 PM
Power inlet dimensions needed Raz Problem Solving | Owners Helping Owners 17 04-18-2015 04:34 AM
Scamp 13 Power Inlet jcassady Electrical | Charging, Systems, Solar and Generators 7 05-24-2014 07:30 PM
Power cord and Inlet Question bomni Modifications, Alterations and Updates 10 04-09-2012 09:59 PM
