Furrion 30 amp power inlet - Fiberglass RV
Old 05-12-2016, 02:40 PM   #1
CampyTime's Avatar
Trailer: Scamp 13' Standard
Hello Friends.
I'm tired of the 30 amp power cord getting clustered under the bench when I hook up. Thinking of buying the round 30 amp power inlet by Furrion that comes with the power smart led light. Just a few questions:
I'm sure holes won't line up. Would JB epoxy water weld putty be ok to fill with or a recommendation for other product?
Fasteners? Rivets or SS machine screws and nylon nuts or?
This comes with a gasket, believe size of hole it fits is 2 3/4" anything else I'll need for install? Other than a new detachable 30 amp cord?
Any recommendations for the power cord? Lots of brands out there...
I appreciate your help!
Wendy
Sent from my VS985 4G using Fiberglass RV mobile app
CampyTime is offline   Reply With Quote
Old 05-12-2016, 02:48 PM   #2
CampyTime's Avatar
http://furrion.com/product/power-inl...d-round-white/
Old 05-12-2016, 03:11 PM   #3
I have used Marinco 30 Amp twist-Lock cords and fittings for over 40 years, (mainly on my boats, but I also converted my shore power entrance on my trailer to one as well.) As to your mounting of it, you didn't say where you wanted to do your installation. A picture wouldn't hurt either to see what you are trying to cover up with the JB Weld.
As an aside, I drilled a new mounting hole to fit the Marinco shore power connection that I installed next to the original power cord storage hatch. Not that it is necessary, but I also replaced that hatch with a larger one for better access. Those little hatches are not very user friendly to work in.
Old 05-12-2016, 03:20 PM   #4
CampyTime's Avatar
Hi Greg,
Thank you for writing. In water weld is to cover river holes left from old scamp cord inlet. I'm sure new power inlet holes won't line up.
I don't have a storage hatch in my scamp. Just a plastic cord hole cover that I want to remove and replace with the furrion.
Old 05-12-2016, 06:05 PM   #5
CampyTime's Avatar
I see that Marino and furrion make conversion kits now upon further research. Maybe that's what I need then you get a backing plate and other stuff
Old 05-12-2016, 08:14 PM   #6
rdickens's Avatar
Trailer: 2017 Scamp 16 Deluxe
Missouri
I think we used the Marinco.
The exterior connection is round and the same size as the old pull-out plastic cord opening.
On Scamp Owners International, I saw articles on "sealing up the mouse hole". ☺
Good luck!
Ray
Sent from my SCH-I545 using Fiberglass RV mobile app
rdickens is offline   Reply With Quote
Old 05-13-2016, 04:04 AM   #7
CampyTime's Avatar
Thank you Ray! You and another member pointed me toward a thread on SOI and it has been most helpful. I do feel now that the marinco would be best for me. Actually furrion has discontinued their kit, although you can still find it for sale. Only bad review I read on marinco is one person felt the plastic screw on part could be easily cross threaded. But to me that's just taking care. Just like nylon plug for my water heater. Start backward turn to catch and then go easy.
Old 05-13-2016, 06:12 AM   #8
Originally Posted by CampyTime View Post
...Only bad review I read on marinco is one person felt the plastic screw on part could be easily cross threaded. But to me that's just taking care. ....
I have the Furrion and it feels like it will cross-thread, so I would call that criticism a wash.
Old 05-13-2016, 10:11 AM   #9
Trailer: BigFoot
Tennessee
I had the plastic Furrion inlet like in Greg's pic's, but replaced with this (Amazon):
Furrion F30INS-SS Stainless 30 Amp Marine/RV Inlet
Rzrbrn is offline   Reply With Quote
Old 05-13-2016, 01:07 PM   #10
Sorry, but mine is a Marinco power inlet, not a Furrion.
Old 05-14-2016, 06:53 AM   #11
CampyTime's Avatar
Hi Greg,
I see the marinco kit has what looks like a metal junction box. Would I put this on inside wall of scamp as extra support for FG? Further would you recommend I use rivets as scamp does for original mouse hole or SS machine screws and nylon nuts?
Wendy
Old 05-14-2016, 09:35 AM   #12
Paul O.'s Avatar
Another alternative might be one of those 5x5 inch fence post / railing sleeves many people attach either to the bumper or to the frame underneath. My shore power cord goes now through the floor into the sleeve and comes out of its end when needed otherwise it lives inside of it, neatly folded and slipped in. That way it is still attached to the Scamp, but on the outside.
From pictures, I see that the 13' Scamps ride low and this may not work for you. Just an idea.
Old 05-14-2016, 01:30 PM   #13
CampyTime's Avatar
Hi Paul,
Thank you for writing. The only way I would do that is attached to the bumper. Does your cord go through some type of collar in the floor? Like a plastic sleeve or something?
Assuming you cut the male plug off at first so the hole in the floor isn't quite so big? Then through either a hole stop the fence post or straight down the back end square hole of the tube?
I honestly an just tired of that cord getting so jumbled up in there. It always gets stuck on something. Highly annoying when packing up or unpacking!
Old 05-15-2016, 06:29 AM   #14
Paul O.'s Avatar
On second thought, it might work in your case. The power cord would come out of the floor of the Scamp as far back as possible, then a short distance to a hole in the 5x5 sleeve, which you tie to the bumper. This section is best protected by a piece of a garden hose or a piece of automotive rubber hose. Those holes are only needed to take the cord through, which is about 1/2 inch diameter, and get sealed with Lexel, or like. Don't cut of the connector end, rather disconnect it where it is wired to the converter and pay attention to how it is connected, then thread it through the sleeve, rubber hose, and the small holes and reconnect the way it was. Mark the points on the cord where to fold it, hold it together with a Velcro tie, slide it in, close the tube (sleeve), done.
I mentioned this before in one of my posts, I don't have pics, but if you want to explore this solution, I'll take some. The solutions with the Furrion socket and separate cord are elegant, but expensive, and you can still leave the cord behind by mistake. This solution saved me money for a couple of cases of beer, at least.
Old 05-15-2016, 06:49 AM   #15
I like that post sleeve solution! How severely does the cord get folded to store in the sleeve? I am concerned at the stress that may be put on the wires by folding vs coiling. Thanks.
Darnelle is offline   Reply With Quote
Old 05-15-2016, 07:13 AM   #16
CampyTime's Avatar
I like this idea too Paul very much. Its creative! My only concern is because I have to mount pvc post on front of bumper face, that the 30 amp cord has quite a bit of travel to do before entering post, even covered with hose for protection. My spare tire eliminates a top of the bumper mount as there's no room. My stabs eliminate a below mount. I'm not sure if it will work without post under trailer like you have. Your 30 amp cord goes immediately into post, protecting all the way from road debris and elements. I'm looking at trailer now and I wanna get underneath to see how low a 4" pvc sewer pipe would ride. Probably better option for me than 5x5 fence post
Old 05-15-2016, 01:29 PM   #17
Paul O.'s Avatar
The post being 5x5 in., and the diagonal about 7x7, the cord folding is not too severe. I fold it just enough to make it fit. What works to our advantage is that it is made of stranded wire. When the cord is stuffed into the compartment and then pulled out, it gets tangled and probably bent much worse.
Yes, Wendy, I forgot about the stabilizers that already take up the space under the bumper... The 4" pipe might be too small for the folded power cord. Some other solution might be needed for the 13' Scamps.
Old 05-18-2016, 06:57 AM   #18
rdickens's Avatar
Missouri
I didn't use the metal junction box in the Marinco kit. It doesn't match up well with the curved sides of the Scamp.
If you think you need extra stiffening, I guess you might cut a ring out of very thin wood (Michael's?) or plastic .... something that would conform to the curved side of the Scamp.
Because the gray water tank & outlet are back there (and because I really don't want to break the epoxy seal on the wood floor), I would be very cautious about drilling through the floor. But maybe that is just me ... ??
YMMV.
Ray
power inlet installation question WDavidG Problem Solving | Owners Helping Owners 18 03-20-2016 10:55 AM
Today's Bigfoot project - 30 amp inlet trainjunkie Modifications, Alterations and Updates 2 04-28-2015 07:16 PM
Power inlet dimensions needed Raz Problem Solving | Owners Helping Owners 17 04-18-2015 04:34 AM
Scamp 13 Power Inlet jcassady Electrical | Charging, Systems, Solar and Generators 7 05-24-2014 07:30 PM
Power cord and Inlet Question bomni Modifications, Alterations and Updates 10 04-09-2012 09:59 PM
