GA: Trillium 1300 DE-alteration - Page 18 - Fiberglass RV
Old 01-26-2016, 09:34 PM   #239
Martins HeirCon's Avatar
Trailer: Trillium 1300
Mmmm, think I'll stick to wood. The first sheet lasted 40 years! Got the first patch in tonight.
Name:	ImageUploadedByFiberglass RV1453865396.239839.jpg
Couldn't figure out how else to clamp it. Can't put screws in it. You know what would work great? A waterbed mattress. Wish I had one laying around.
Martins HeirCon is offline   Reply With Quote
Old 01-28-2016, 10:19 AM   #240
David Tilston's Avatar
A bunch of 5 gal pails?
Looks good.
Old 01-28-2016, 10:30 AM   #241
Thanks. Last night I had to add another ply of 5mm to compensate for the gelcoat layer, I weighted it with three group 31 batteries.
5 gallon buckets would work, but all the ones I have are full of and/or covered in some kind of oil. Messy!
How about bags of concrete? Hmmm.
Old 01-28-2016, 05:25 PM   #242
Another layer of resin and cloth
Name:	ImageUploadedByFiberglass RV1454023524.226709.jpg
Old 01-29-2016, 09:35 PM   #243
I intended to add the finish layer of plywood to the floor tonight, but the (probably too thick) layers of 'glass from yesterday weren't fully dry. There was also some puckering at the thickest joint, so I decided to let that fully cure before covering.
I sanded the rest of the floor just to knock down the 'boogers', and coated the bottom of the fridge cabinet with resin.
Name:	ImageUploadedByFiberglass RV1454124898.699432.jpg
Maybe that will let it shed whatever water gets in there.
Old 01-31-2016, 12:07 PM   #244
The old carpet really helped as a template. There ain't nothing square about an egg!
Name:	ImageUploadedByFiberglass RV1454263593.920855.jpg
Dry fit. Just a couple of adjustments, then glue it up!
Name:	ImageUploadedByFiberglass RV1454263661.090899.jpg
Old 01-31-2016, 01:46 PM   #245
600# of concrete mix, 2 batteries and several 2x2s propped to the roof. I hope that makes it bond void-free. I used 3 large tubes of polyurethane adhesive, buttered and troweled on the substrate and on the back of the finish subfloor. Click image for larger version
Name:	ImageUploadedByFiberglass RV1454269587.769771.jpg
Old 02-01-2016, 01:01 PM   #246
I bought a sheet of marine grade 3/4 plywood to use for the window strips. Went ahead and ripped enough to do all of the openings. Click image for larger version
Name:	ImageUploadedByFiberglass RV1454353284.946347.jpg
Can anyone tell me what kind of screw works best? I'm thinking #10 x 1"?
Old 02-05-2016, 07:46 PM   #247
Bought #8 x1".
Got the opening framed and the window prepped tonight.
Name:	ImageUploadedByFiberglass RV1454723078.761084.jpg
After scraping all of the old sealer off, a Scotchbrite pad and some acetone really cleaned the aluminum nicely.
Name:	ImageUploadedByFiberglass RV1454723169.349802.jpg
Old 02-07-2016, 08:39 PM   #248
Got the window in, double butyl tape and added a dab of sealer to each screw. Click image for larger version
Name:	ImageUploadedByFiberglass RV1454898839.390907.jpg
Tightened the screws in several progressive steps, kinda hard to know where to stop squishing. Click image for larger version
Name:	ImageUploadedByFiberglass RV1454899013.534942.jpg
Or how to finish off that mess afterward. I trimmed it up, but the following day it had oozed more.
Meanwhile, work continues on the floor and front dinette. Click image for larger version
Name:	ImageUploadedByFiberglass RV1454899175.797996.jpg
Name:	ImageUploadedByFiberglass RV1454899193.266425.jpg
Old 02-08-2016, 10:37 PM   #249
Finally got the benches assembled. Click image for larger version
Name:	ImageUploadedByFiberglass RV1454992218.729531.jpg
Made removable floor sections for the corners, just in case we need access. The body bolts are under there!
Name:	ImageUploadedByFiberglass RV1454992371.058800.jpg
Since the battery converter/ wiring/ gas line are all right there on the side of the fridge, i put a curb on that floor piece to guard the works. Click image for larger version
Name:	ImageUploadedByFiberglass RV1454992638.065603.jpg
Old 02-16-2016, 09:22 AM   #250
Here's a semi-finished view. Haven't got the table engineered yet, for this trip it will still be a gaucho with a gap.
Name:	ImageUploadedByFiberglass RV1455636151.679804.jpg
Old 02-17-2016, 09:57 AM   #251
I am impressed!
I can't tell if you did front dinette in fibreglass, or wood. Looks like glass. Any plans to put a door on the seat nearest the trailer door? That is were Trillium puts what they call the porta potty garage.
Old 02-17-2016, 10:59 AM   #252
Timber Wolf's Avatar
North Florida
Attachment 92580
I love the phrase "Gaucho with a gap". I will remember that years from now when I get around to my front dinette mod. I can say; "I am doing a front dinette mod, but so far all I have is a Gaucho with a gap".
CANADA - Trillium 1300 - $1300 David Tilston Referrals: Molded Fiberglass Trailers 2 01-26-2016 01:34 PM
OH | 1981 Trillium 1300 Trade for a Trillium 4500 Gene Griffin Classified Archives 13 03-06-2011 08:27 AM
Wanted Hammock Alteration Pics Jakeh Modifications, Alterations and Updates 2 10-17-2008 06:50 PM
Interior alteration wes harris Problem Solving | Owners Helping Owners 2 11-15-2005 12:48 PM
» Virginia Campgrounds
