GA: Trillium 1300 DE-alteration - Page 16 - Fiberglass RV
Old 09-27-2016, 04:47 AM   #301
Martins HeirCon's Avatar
Trailer: Trillium 1300
I'm working on adding AC Under the left front dinette bench (next to the fridge). My intention was to use the window unit that I bought for my Keys trip with my Dad last year, but I find that it's a little too wide for the space.
After scouting all the local stores for end-of-season deals and finding only xmas stuff (in September! Grrrrrr. ) I ordered a smaller 15"wide unit online. It's supposed to deliver today.
If anyone wants this year-old LG with maybe 100 hours on it, I'll make you a deal! I've long since chucked all the window hardware, so it's really only good for a built-in.
Martins HeirCon is offline   Reply With Quote
Old 09-27-2016, 07:41 AM   #302
Johnny M's Avatar
Deep South
Originally Posted by Martins HeirCon View Post
John, is Allrite a manufacturer? I searched a bit but what I found was in Cali.
Yes I think they are based out of California but they have a location here in Georgia in the Conyers/Lithonia area. I bought seals for my jalousie windows there.
I should add that they specialize in custom doors and windows.
Old 09-27-2016, 10:31 AM   #303
Thanks, John!
Another question: I'm shopping for a roof fan replacement. Looking at Fan-tastic fans, ran across Maxxair as well.
Anyone have any preferences? Why?
I'm interested in the base model, no remote or rain sensors, maaaaybe reversible. Thoughts?
Old 09-27-2016, 02:31 PM   #304
Johnny M's Avatar
Deep South
I bought a standard Heng vent fan wish now we got something different as it doesn't move much air
Sent from my XT1032 using Fiberglass RV mobile app
1971 Boler 1300 - "Suite 13"
1987 Play-Mor II - "The Beach House"
Old 09-27-2016, 04:50 PM   #305
David Tilston's Avatar
I have installed the Fantastic fan. Non reversible, and only 3 speeds. It moves lots of air. I was napping in the afternoon, by the only open window. It was like a breeze was constantly blowing over me. If someone opened the door, my breeze went away, and I realized how hot it actually was.
I have two Maxxair fans, waiting to be installed. The motor is slightly higher amperage, so in theory, it should move more air, but due to its less straight air path, I would be happy if it just moved as much air as the Fantastic fan. The additional complexity comes with the ability to run the fan in the rain. Nice!
Speed control, and a reverse switch can be added later, if you are comfortable doing some wiring.
http://www.fiberglassrv.com/forums/f...tor-64815.html
Old 09-27-2016, 07:02 PM   #306
I did the exact same thing. Tiny fan and noisy.
Old 09-27-2016, 07:26 PM   #307
David, I don't understand what you mean by less straight air path and running in the rain. Guess I need to research more, I thought it was just a different brand of a similar item.
Old 09-28-2016, 03:21 PM   #308
On the deluxe model, the cover on the fan is longer then the 14" vent opening. The inlet for the air is on the bottom of the cover. The fan exhausts, (or draws) air through the bottom of the cover. This allows the fan to operate in the rain.
Old 09-28-2016, 04:28 PM   #309
I see! Thanks, Dave.
Well, my new AC arrived today, damaged. Dangit, I want to have it operational by my Florida vacation next week. I have 30 days to ship this one back, so I believe I'll just mock up the install with it.
Name:	ImageUploadedByFiberglass RV1475101682.521623.jpg
ID:	100146Click image for larger version
Name:	ImageUploadedByFiberglass RV1475101716.929832.jpg
Old 09-28-2016, 08:41 PM   #310
And another question:
What does the original door striker plate look like? Mine is poor.
Name:	ImageUploadedByFiberglass RV1475116672.447980.jpg
I have this piece which came with a Bargman rebuild kit, but I don't see how it would ever work in this application.
Name:	ImageUploadedByFiberglass RV1475116761.793524.jpg
I can fabricate whatever I need, would just like to see how it was supposed to be. Been sitting on a $150 new door seal until I resolve this detail.
Old 09-28-2016, 10:44 PM   #311
Johnny M's Avatar
Deep South
Your plate looks like my older Boler one which I removed when I put on the new style lock. It came with a strike plate similar to your new one but I made a slight error in rebuilding my door as I made it to tight of a fit so with my new trim with the bulb seal it won't close so for now I have not installed the trim seal or the strike plate. The latch and the deadbolt both work they just latch onto the fiberglass instead of the metal plate. Btw in your picture of the a/c it looks like the damage was only some bent fins, you may be able to carefully straighten them, probably won't effect the performance.
Old 09-29-2016, 09:56 AM   #312
Thanks John. If I wasn't paying full price I might accept that damage. I tested it and it works, but is dented on three sides.
Old 10-01-2016, 10:59 AM   #313
Here goes nothing!Click image for larger version
Name:	ImageUploadedByFiberglass RV1475341154.399281.jpg
ID:	100218Click image for larger version
Name:	ImageUploadedByFiberglass RV1475341189.388586.jpg
Old 10-02-2016, 07:49 AM   #314
Johnny M's Avatar
Deep South
Here goes nothing!Attachment 100218Attachment 100219
Nice job Glenn, very professional looking. I am guessing the port is for pulling in cooler air, so are you venting the hot air through the bottom or another port? On mine I pulled cool air from under the trailer and vented the hot air out the side with a soffit vent that looks similar to the 3 way fridge vents but only a couple bucks at Lowe's. I considered adding a couple of computer fans behind the vent cover as others have done here but there is plenty of positive pressure from the condenser fan to push the hot air out so I don't think adding those vans have much effect. I do like your port though as you can close them to keep the elements and bugs out when not using the a/c.
Old 10-02-2016, 08:46 PM   #315
There's an identical port on the side for exhaust.
Name:	ImageUploadedByFiberglass RV1475462615.755436.jpg
Built ducting from foil-faced foam sheathing. Click image for larger version
Name:	ImageUploadedByFiberglass RV1475462693.872622.jpg
Also had to add an outlet to serve the AC. You can see it lower left.
CANADA - Trillium 1300 - $1300 David Tilston Referrals: Molded Fiberglass Trailers 2 01-26-2016 01:34 PM
OH | 1981 Trillium 1300 Trade for a Trillium 4500 Gene Griffin Classified Archives 13 03-06-2011 08:27 AM
Wanted Hammock Alteration Pics Jakeh Modifications, Alterations and Updates 2 10-17-2008 05:50 PM
Interior alteration wes harris Problem Solving | Owners Helping Owners 2 11-15-2005 12:48 PM
