Generator Mount Location - Fiberglass RV
Old 11-29-2011, 07:49 PM   #1
Trailer: Scamp 16ft
I have an 85 16 ft Scamp.
I purchased a Honda EU 2000i generator and I am debating where to mount it. My preference is to mount it on the tongue using a rack welded from the tongue extending over the battery box. The trailer shop where I would be having the work done suggested that I should mount it at the rear where I have a luggage rack. Their feeling is that the front mount would present a fire hazard with the generator mounted next to the propane cylinder.I understand their point however I am concerned about weight bias with a rear mount.
Carrying the generator in the tow vehicle is out of the question as it is a Hyundai Santa Fe and would have to be carried inside.
I appreciate any thoughts or advice on this issue.
William Brown is offline   Reply With Quote
Old 11-29-2011, 09:37 PM   #2
Trailer: Fiber Stream
I don't have a generator, but I have observed that most people make a place for it on the tongue, by 4:1.
Old 11-29-2011, 10:13 PM   #3
Joy A's Avatar
Here's mine
Joy A. & Lily
and "Puff", too
No. Ca. Sierra Foothills
Old 11-30-2011, 07:05 AM   #4
cpaharley2008's Avatar
I'm curious why you bought the 2000 vs 1000? How many amps do you need?
ARe you permanently mounting it on the trailer or just carrying it for use off the trailer? Yes, I would not operate it while attached to the trailer, the noise and vibration and proximity to the propane is an issue.
Old 11-30-2011, 08:26 AM   #5
Trailer: 2015 Escape
I carried our Honda 2000 on the tongue of our Egg Camper for one 5000 mile trip. I had it covered with a propane tank cover. Even with the cover the generator got very dusty and dirty from wet roads and dirt roads. Now it rides in the back of the truck. If I ever put it on the tongue again it'll be inside a tongue box.
Old 11-30-2011, 10:36 AM   #6
Trailer: Scamp 16ft
Generator mounting
Thanks for the information. I am considering mounting it on the tongue and enclosing it with some sort of box. In order to deal with the safety and vibration issue I would remove it from the bracket and use it away form the trailer.
Old 11-30-2011, 10:40 AM   #7
Do you know what your tongue weight is now? Do you have 2 propane tanks and a battery up front?
Old 11-30-2011, 10:46 AM   #8
Trailer: Scamp 16ft
I recently weighed it at 280 lbs. At the present time it has one group 27 battery on it and it will have a single large propane cylinder.
Old 11-30-2011, 11:53 AM   #9
So with a 60 lb gen plus another 30 lbs for tool box you are closing in on 400 lbs t/w. Have you given any thought to solar? With a luggage rack on rear with gear and 400 lbs on front, you maybe overloading your frame and your trailer.
Old 12-01-2011, 09:43 PM   #10
Trailer: Escape 5.0 (sold) :(
Rubbermaid makes a tub that fits the Honda perfectly. We have carried ours in the SUV for thousands of miles with no odor, no problems.
Marv is offline   Reply With Quote
Old 12-02-2011, 03:10 PM   #11
Joy A's Avatar
I carried mine like that for quite a few years but got tired of lifting it in and out of the tow vehicle, having to chain it to the trailer and dragging the electric to it. I rarely used the generator, which I actually purchased mostly for the A/C.
Since mounting the generator on the tongue of the trailer with a dedicated electric cord running under the trailer, into the rear cabinet, with an outlet attached; I have more hours on the generator in the last 2 years than it ever had in the first 9 years.
Now when I want to use the generator all I do is plug the trailers electric cord into the outlet and crank up the generator. In addition everything is out of the elements.
Joy A. & Lily
and "Puff", too
Old 12-02-2011, 03:30 PM   #12
Jane P.'s Avatar
Trailer: Bigfoot 19 ft
I decided to put add a back porch for my generator. But ... being interested in safety while towing, I weighed my trailer (fully loaded); and also weighed the tongue; and the trailer and TV combined. I did consult with Frederick and he was extremely helpful.
I then researched the effects of adding the generator and "porch" to the back of the trailer. The danger of having too much weight in the back of the trailer is that the front will tend to lift up while under way, causing instability [a crash ]. You want to make sure that your trailer will handle the additional weight safely.
Also, think about where your fresh water tank is located. If you tow with a full H20 tank (I just keep a minimum amount of H20 on the road and fill up near my destination), you'll have to include that in your calculations.
If it is safe, a back porch is a great way to go. I made a cover for the generator. But a large trash bag and bungie cords will work just fine. I do not carry a gas can on the porch. I put gas in the generator close to my destination and manage to use most of it up before returning home.
'92 Bigfoot 19' | '07 Chevy Tahoe
Jane P. is offline   Reply With Quote
Old 12-02-2011, 10:18 PM   #13
Trailer: Scamp 16ft
That sounds like a good plan. I am in the same situation .Thanks
generator
Best location for a ground DannyH Problem Solving | Owners Helping Owners 11 11-18-2010 09:30 AM
TV location in new Escape 19? DannyH General Chat 7 03-22-2009 07:11 PM
AC location William L. Care and Feeding of Molded Fiberglass Trailers 8 10-08-2008 12:13 PM
AC location William L. Modifications, Alterations and Updates 0 01-01-1970 12:00 AM
