Generator storage box for Casita - Fiberglass RV
Old 01-28-2003, 11:32 AM   #1
After we got our new 17-foot Casita SD last year, I decided to get a Honda EU2000i generator. But, where to store it in transit? Since we pull the Casita with a Nissan Pathfinder, I couldnít carry it in the back of the tow vehicle. I liked Mike Sandersí nifty storage box, but I didnít want to lose the second propane tank. I decided to have an aluminum box made to fit on the tongue between the propane tanks and the tongue jack.
To make the space I needed, I replaced the original rigid propane tanks cover with a vinyl, zippered cover, available at Camper World for $20. The generator fits snuggly in the box, which has two hinged lids, one on top and one on the one end. (See the accompanying photo.)
There were several additional modifications required. First, since the tongue at this point is not level, I had two brackets welded onto the tongue. Second, the box interfered with the handle on the tongue jack, so I extended the handle up about 5 inches. Third, I added a shelf behind the propane tanks to accommodate three, 1-1/4 gallon plastic gas cans (see photo).
A couple of observations: This adds about 60 to 90 pounds to the tongue weight, depending on the amount of gas you are carrying. If this is a problem, it can be compensated for in part by allowing one propane tank to be empty or nearly so, and keeping your black water tank empty (and donít pile your closet full of heavy stuff). On the plus side, the vinyl propane tank cover is really nice. No more taking the cover off to turn the tanks on or off, or to switch the regulator. Just pull the zipper open and reach in.
If anyone would like details, send me an e-mail, and Iíll be glad to share.<img src=http://www.fiberglassrv.com/board/uploads/3e36cc8d15abbGenerator box.JPG/>
Old 01-28-2003, 11:46 AM   #2
Hitch Storage Box
Looks good Dave,
You didn't say how much the cost of the box was.
Old 01-28-2003, 04:46 PM   #3
Tie down that tank cover
Dave, Yours is protected by your box, which should help some, but -
Those soft-side propane tank covers can blow off in transit. They need to be tied (or bungeed) down, across the bottom.
The one we had had elastic around the bottom. Lasted barely over a year, then, whoop, it was gone.
:sunny
Old 01-28-2003, 06:18 PM   #4
I'll buy the bungee cord
if someone will buy me the Honda EU2000i :o :o
Old 01-28-2003, 06:30 PM   #5
Rick-I am suprized at you. A man of you calibar. Bumming on this forum.:nono :laugh
Old 01-28-2003, 06:34 PM   #6
bumming
I was thinking if we all took a trip together, I'd want behind Mary's trailer. I could sure use a tire cover. is that bumming?
Old 01-28-2003, 06:38 PM   #7
Jana-Thats taking advantage of a friend.:nono A little sneaky for a me.;)
Old 01-28-2003, 11:36 PM   #8
Generator box
To answer a couple of the questions:
I had the box made at a local sheet metal shop. I donít remember the exact cost , but I think it was around $150. It is made of 0.090 aluminum diamond plate with stainless piano hinges, which made it a little pricey. Steel would have been cheaper, but I didnít want to have to paint it.
As for the tank cover blowing off, I doubt it, although time will tell. While the box isnít smack up against the tanks, it is quite close and also serves as a wind break. More importantly, the bungee cord holds the gas cans tight up against the tanks, so they should hold it on if nothing else does. In reality, I havenít given it a good road test yet. Iíll try to remember to let you know.
Thanks for your interest.
Old 01-29-2003, 06:10 AM   #9
tank cover
posted by Dave>>As for the tank cover blowing off, I doubt it, although time will tell. While the box isn't smack up against the tanks, it is quite close and also serves as a wind break. More importantly, the bungee cord holds the gas cans tight up against the tanks, so they should hold it on if nothing else does. In reality, I haven't given it a good road test yet. I'll try to remember to let you know<<
I think your right. Looks good and snug in there to me too, but as I've never had a propane cover.. :conf Now which road are you taking that trip??? maybe I'll just come follow behind. :E :E :)
Old 01-29-2003, 08:22 AM   #10
Propane tank cover
Jana, :wave
It'll take awhile before that cover blows off - and, as Dave says, his may be so well sandwiched in there it'll never go.
Or he might add a couple of grommets along the bottom and tie it down anyway. Such an easy thing and only would need to be undone when pulling the tanks off to refill; as Dave said, the zippered top of the cover provides easy access for turning the propane on and off.
Now Carol Christensen shared her pattern with me for making a propane tank cover, but if we want to talk about sewing, we should probably move it to a New Topic, huh? :laugh
:cblob
Old 01-29-2003, 09:11 AM   #11
Off topic
My propane cover is much tougher than the flimsy white one I started with. But I will probably replace it with a hard cover sometime this year.
If it was yellow instead of Casita blue Jana could have it.
<img src=http://www.fiberglassrv.com/board/uploads/3e37fc5c0d8cbPropane Tank Cover.JPG/>
Old 01-29-2003, 02:22 PM   #12
yellow and not blue
Humf!! :wak Carol!! you should have thought of that before you made it. :sad like *I'll use this a little while, then give it to Jana, so I better make it yellow.* :reye2 Maybe there is a Casitaite that could use it. Casitan.. :conf
Old 01-29-2003, 02:37 PM   #13
Honda EU2000i
Got my dad looking for a slightly used genset in Quartzite AZ tomorrow. He seems to remember seeing lots there. They're probably hot - but I hope not. :E :E
$850.00 for a new one is not in the plans - yet. :reyes
With the propane (2-30lbers) and battery cover on my Bigfoot I don't know where to mount it, if at all. :wak
<img src=http://www.fiberglassrv.com/board/uploads/3e38497e133ffDSCF0001.jpg/>
Old 01-29-2003, 02:44 PM   #14
where?
My first thought was... do you really use both tanks when camping? maybe you could take one tank off and put it there.
casita, generator
Using a casita for storage ...OY Flygal General Chat 3 01-27-2009 08:00 AM
Storage of Honda Generator Loren G. Hedahl Problem Solving | Owners Helping Owners 18 10-29-2008 07:07 AM
Just got the Casita out of winter storage. Harvey Craft General Chat 2 04-21-2006 04:54 PM
Storage, Storage, and Storage Legacy Posts Problem Solving | Owners Helping Owners 18 11-20-2002 09:43 AM
Storage, Storage, and Storage Modifications, Alterations and Updates 0 12-31-1969 07:00 PM
