Glad I checked the mounting bolts today - Page 2 - Fiberglass RV
Old 04-27-2015, 10:59 AM   #15
You have a point! 6 bolts doesn't sound like much holding the body onto the frame but if those rusty bolts held on for 40 years, we're probably good with any bolts as a replacement.
ajdemo76 is offline   Reply With Quote
Old 04-27-2015, 11:04 AM   #16
David Tilston's Avatar
Just an FYI, on a Trillium 4500, there are 8 bolts. Four bolts in the gaucho, two under each dinette seat.
Old 04-27-2015, 11:09 AM   #17
frank_a's Avatar
Trailer: 2012 ParkLiner #006
If it was me, I would drill 5/16 out to 3/8. No problem finding 3/8 fasteners!
Frank
2012 ParkLiner #006
2013 4wd Escape 2L Ecoboost with 3500# tow package
Old 04-27-2015, 11:24 AM   #18
Dennis mn's Avatar
Originally Posted by Timber Wolf View Post
SS is great but maybe a bit of over kill in this circumstance. If mild steel lasted 40 years maybe some new galvanized hardware would do for another 60? I can just hear the conversation in the future: "dang bolts rusted through on my 100 year old FGRV, dadgum that previous owner!"
When I worked in factory maintenance, we had a rule of thumb that if it survived four years, replace it with carbon steel, if not, use stainless.
1999 Scamp Fifth Wheel, pulled by a 2014 Nissan Frontier Pro4-X
Dennis mn is offline   Reply With Quote
Old 04-29-2015, 08:44 PM   #19
Trailer: 1985 BigFoot G
Mississippi
WOW that's scary. So I guess I need to get hubby to check those to since our Bigfoot is a 1984-85. Now I wonder WHERE those bolts would be on ours.
Gardnpondr is offline   Reply With Quote
Old 04-30-2015, 11:50 PM   #20
dleverton's Avatar
Trailer: Trillium 1300 1973
I would be hesitant to drill the front bolt holes larger as that is the weak point on the frame where it has broken on so many Trillium's. I suspect your original bolts broke after 40 years of corrosion and new 5/16 will last another 40 years.
Doug L
Doug
dleverton is offline   Reply With Quote
Old 05-01-2015, 02:52 AM   #21
Raz
Raz's Avatar
Vermont
Something has been bothering me about this and I finally figured out what. My Trillium doesn't have 5/16" bolts, it has 7/16" bolts which is why they were hard to find. The bolts attach to tabs welded to the side of the frame. Raz
Old 05-01-2015, 03:30 AM   #22
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Raz, being yours is a 2010 model was that bolt size from the builder?
Old 05-01-2015, 04:43 AM   #23
Raz
Raz's Avatar
Vermont
Yes except the bolts they used were too long. Not enough thread to tighten. They tried to fake it with lots of extra washers but they were still loose. I was checking under my trailer when I spotted them. I had to order the correct size. Raz
Old 05-02-2015, 07:48 PM   #24
Got the bolts on today since the weather is finally cooperating. One thing I noticed, the bolts right behind the wheels need to be slightly longer. Maybe 1/4". I'm using a flat washer and lock washer on the others. Only able to get a flat washer on the middle bolts. No big deal. Just an fyi in case someone else is doing this in a Trillium.
Old 05-04-2015, 09:29 AM   #25
Trailer: 1978 Trillium 4500
David, could you do one of your wonderful drawings with the location of these bolts. (trillium 4500) I am also confused a bit as people say the floor is fiberglass/plywood/fiberglass yet the floors of my compartments are plywood.
Two of the rear bolts have been replaced but the other two look pretty gone. I can only find two in the dinette area, not four.
Thanks greatly for all you do.
Island Bolers and Friends on Facebook
Island Claire is offline   Reply With Quote
Old 05-05-2015, 01:56 PM   #26
I will update my frame drawing to show the bolt locations.
Trillium Body Mounting Bolts Larry C Hanson Problem Solving | Owners Helping Owners 3 09-03-2015 10:54 AM
Checked out the Scamps at the MN State Fair Mary Ann in MN General Chat 16 08-28-2013 10:43 AM
I checked out the Airstream Basecamp yesterday... John Mc General Chat 11 02-10-2008 09:51 PM
Needed a trailer checked out:Tacoma Kent I Problem Solving | Owners Helping Owners 5 10-20-2007 06:24 PM
Today's problem: back to mounting the propane tank Bobbie Mayer Problem Solving | Owners Helping Owners 15 09-09-2007 08:47 PM
