Glue removal - Fiberglass RV
Old 10-20-2017, 10:46 AM   #1
Glue removal
Has anyone found an easy way of removing the glue that is used to glue the inside skin of a Scamp to the shell? It's a 1977. I'm removing pieces to add tabs, and the stuff keeps on gumming up my sandpaper.
jeroen is offline   Reply With Quote
Old 10-20-2017, 12:15 PM   #2
IllAnnoy
How about Goof Off or Krud Kutter I haven't tried either...
Check it out and let us know!
Old 10-20-2017, 12:36 PM   #3
Raz
Raz's Avatar
Vermont
I tried Good Off. It smells and feels alot like Acetone. My wall covering was put on with contact cement. No chemicals I tried would remove it. I had to remove the covering up to the belly band to repair leaks , I used 60 grit sandpaper; by hand, no sander. Sanded to fiberglass where the repairs went. Every where else I just roughed things up and applied new cement to reapply the wall covering. Not fun. Do wear a mask, eye protection, etc. Good luck, Raz
Old 10-20-2017, 02:02 PM   #4
ststefan's Avatar
Trailer: 1979 Boler1700
Maple Ridge, B.C.
Try this. http://www.kleanstrip.com/product/ai...hesive-remover
Old 10-20-2017, 02:14 PM   #5
Trailer: 2014 Escape 21
Virginia
A twisted wire brush on a drill or 4"/4.5" grinder to prep for tabbing works great. Just wipe down with a solvent before glassing. A grinder with a cutter wheel will cut through the shell easily. I really haven't found a good solvent that would work on the glue that you could work with in a confined space.
Eddie
Eddie Longest is online now   Reply With Quote
Old 10-20-2017, 03:22 PM   #6
Floyd that stuff works on glue like crazy I have laid my own carpet and of course since being an amateur I made goof ups! get the name!
bob
Old 10-23-2017, 11:13 AM   #7
Trailer: 1987 Casita 16
Illinois
If you are going to gut the whole thing then you can take out the windows and remove everything inside and power wash the glue out, 3400PSI is what I used. Obviously won't work for small places, or if anything is left inside. But I was able to do the entire inside of a 16 Casita in a couple of days.
EricAllyn is offline   Reply With Quote
Old 10-23-2017, 11:19 AM   #8
I'm going with Eddie's tip of using a wire brush on a drill. I only need to clean a few 4x8 sections to fiberglass tabs to the wall to attach cabinets and such to.
Old 10-31-2017, 06:10 AM   #9
Power sanding will heat up the glue and make it soft. That is why you get the gumming up, it is the generation of the friction heat that is doing that.
I hand sand it with coarse 80 grit paper. Takes a little longer than a power tool but it gets the job done faster than you might think and does it without any gumming issues.
What glue is the best to glue the fabric on the sealing. Falicea Problem Solving | Owners Helping Owners 11 10-31-2017 09:22 PM
Scamp Door Seal Glue Removal?? TomK Care and Feeding of Molded Fiberglass Trailers 18 03-13-2016 12:31 AM
71 Boler 13' Floor Removal/ Shell removal mikeandmadi Problem Solving | Owners Helping Owners 1 05-23-2011 10:28 AM
Seam tape glue removal Steve Smith Problem Solving | Owners Helping Owners 4 06-27-2009 10:37 PM
Adhesive to glue foam cushions together? Legacy Posts Problem Solving | Owners Helping Owners 4 03-12-2003 08:37 PM
