After all of that is when the real work begins. Putting it all back together is a fairly major undertaking. I did put those ears back on the side of the steps and applied new
fiberglass and resin there so it's sort of like it was before. I am not sure what those do but I did put a few screws through them from the inside out.
One area of warning - when I went to put the front bench in, it wouldn't sit right. It looks like the bottom actually rests on the metal frame and the floor butts up to it. I ended up cutting off a little off the bottom of the bench since there was no way I was going to be able to remove 1/4 inch of flooring under that shower overhang. The same thing happened on the side cabinet right by the door. I was able to cut that section of the floor out with an oscillating multi-tool.
Like I said, from this point on is actually a lot of work. Hooking the gas back back up, installing trailer chains, mounting the
battery box, running new electric brake lines, putting everything back inside, and everything else takes forever. I barely finished in time for our trip. By the way, the new five hole wheels still fit the four-hole bracket on the back with no modification. I bought a mounted spare at Northern Tool.
