Granite counter top in Boler - Fiberglass RV
Old 08-06-2010, 07:20 PM   #1
Went a bit up scale on my boler repairs and installed a Custom granite counter top with a household kitchen tap
billyb_1969 is offline   Reply With Quote
Old 08-06-2010, 09:29 PM   #2
Trailer: Casita Spirit Deluxe
Beautiful countertop. I also like the back splash.
Bill&Ann is offline   Reply With Quote
Old 08-06-2010, 11:14 PM   #3
Thanks Previous owner did the metal back splash, its not so nice in person in my eyes I am going to get a granite 4 1.2" back splash to match as there is a bit of a space by the wall. I will replace that tin with something more appropiate if I can find something that works better.
Old 08-14-2010, 08:52 AM   #4
Do you have any idea what the change in weight may be from original to granite? Looks nice! I've thought about changing the countertop in my Scamp from original to Corian (with a molded deeper sink), but it would be really heavy in comparison to original.
Old 08-14-2010, 12:21 PM   #5
It weighs 43 lbs -5 lbs for the original wood. Its 3/4" and my granite guys used the original top as a template so I could reinstall every thing as same. I have a back splash on order 4.5" high so that will add a few more pounds. But to have a nice countertop that will not come unglued after a couple of years due of moisture or is just dated looking.
If weight is a real concern then you just have to watch how much crap carry with you on your trip and leave the 42" big screen at home
Old 08-14-2010, 07:10 PM   #6
I'm not concerned, but others might be.
Old 08-15-2010, 03:44 PM   #7
Pam Garlow's Avatar
Trailer: U-Haul 1985
Is this solid granite (how thick?), and are you concerned that it will crack if you hit some hard bumps? I see installers being soooooo careful when installing it in houses, and I've heard that it can sometimes crack quite easily in the right circumstances.
How is it attached to the countertop? (and, by the way, I LOVE it!)
Old 08-15-2010, 04:15 PM   #8
Matt in SV's Avatar
Some specs are up there in post 5
Planning our next Escape!
Old 08-17-2010, 11:53 AM   #9
Install was done the same as home installs you need to reinforce the under side with plywood the original counter frame does not have enough meat to adheare the granite. Its the flexing that usually causes cracking for example the small strip infront of sinks
boler, counter
Boler flat top sidney lewis Care and Feeding of Molded Fiberglass Trailers 43 08-12-2017 08:11 AM
Boler 13' Top of Door Gap Emily R. Problem Solving | Owners Helping Owners 1 10-17-2009 01:12 PM
Roof top A/C for 13' Boler Fred B Problem Solving | Owners Helping Owners 2 03-24-2009 07:58 AM
Trade Granite Countertops for Scamp-MN Greg A Wanted: Molded Fiberglass Travel Trailers 0 04-14-2008 05:49 PM
painting the counter top Paula D. Problem Solving | Owners Helping Owners 8 07-15-2006 07:40 PM
» Virginia Campgrounds
