gray water tank install - Fiberglass RV
Old 02-15-2012, 02:33 PM   #1
thunter's Avatar
Trailer: 2008 16ft Scamp
We bought A 84 scamp 16ft.camper had no gray water holding tank. I had a 10 gal.. fresh water holding tank from old pop up. I installed under sink in cabnet Do not know how to send pit. Drain comes out at regular gray water drain.Tank sets on shelf on top of tire well. Takes up some cabinet space but better than having can setting beside camper.Installed with plastic cut off under sink in drain. It was a real tight fit getting it under the sink but with a good bit of work I did it. I thought someone else could do the same thing. thunter
thunter is offline   Reply With Quote
Old 02-15-2012, 06:18 PM   #2
Kenneth, thanks for the post and the information. Quite a number of the older molded trailers came stock without a gray water holding tank. The information you've provided will be a great benefit for those looking to install something that works without slinging a holding tank under the trailer
Gray water tank Roger Kimble Modifications, Alterations and Updates 0 12-04-2011 07:48 PM
Gray Water Tank Release Susanm34 Plumbing | Systems and Fixtures 8 09-04-2011 07:45 PM
Gray water tank for '91 Casita Geoffrey Cobb Problem Solving | Owners Helping Owners 1 10-11-2007 11:38 AM
Gray water w/out tank Janine Problem Solving | Owners Helping Owners 10 08-29-2007 03:06 PM
Gray Water Tank Leaking Legacy Posts Problem Solving | Owners Helping Owners 6 06-02-2003 10:04 PM
