Guess what I'm using for insulation! - Fiberglass RV
Old 06-05-2011, 06:27 PM   #1
Andrew GPSMapNut's Avatar
Trailer: Modified Trillium Jubilee
Guess what I'm using for insulation! The answer is in the pictures. What do you think of the idea?
I wish to be one day at least half as good as I think I am today. Andrew Kalinowski
Photography: http://www.FotoCanada.ca
Maps: http://www.CanadianMaps.ca
GPS hobby: www.GPSNuts.com
Andrew GPSMapNut is offline   Reply With Quote
Old 06-05-2011, 06:45 PM   #2
Trailer: Fiber Stream
Cool
I like that!
Old 06-05-2011, 07:44 PM   #3
Trailer: Two Trillium Jubilees and a Trillium 1300
Send a message via MSN to Bill Reilly
Insulation
Andrew
Looks good. ? What is it and where did you buy it ?
Seems easy enough to apply. What adhesive did you use ? How do you plan to finish it ?
Bill
Bill Reilly is offline   Reply With Quote
Old 06-05-2011, 07:52 PM   #4
Saskatchewan
Is that insulation those 'jigsaw' mats? My daughter has some on her basement floor.
Hazel in Sk is offline   Reply With Quote
Old 06-05-2011, 08:06 PM   #5
It is EVA, high density, closed cell foam. Comes in 2'X2' squares, 3/8" thick. On "special", in Canadian Tire, I paid about $7.50 for a pack of four.
As long as you are dealing with flat and square surfaces it is easy to apply. It's very flexible but not really stretchable so... you have to do some magic (=elbow grease / cutting/fitting) to make the joints match on a wall of a trailer where nothing is flat nor straight...
Glue... I have no idea. I got it from my friendly neighbouring company. It's some sort of industrial, nearly odourless, safe for people, honey consistency, acting like a contact cement, honey consistency stuff. They use it on in/outdoor instalations of insulations and other stuff.
Finish? I thought that; since it is so colourful, other than having a stiff drink once I'm done gluing it on, it is finished...
Old 06-05-2011, 08:18 PM   #6
Originally Posted by Andrew GPSMapNut View Post
It is EVA, high density, closed cell foam. snip ....
Forgot to ad; we did few tests and it is not too hard to paint and it is not too mushy so, a decent quality water based emulsion does not crack / peel when pushed on. Still, we decided not to paint it... for now. As it is, it should be easy to clean and naturally, it is (supposed to be) mould resistant.
Old 06-05-2011, 09:09 PM   #7
I LIKE it!
Old 06-05-2011, 09:25 PM   #8
Trailer: 1984 UHaul CT13
That's the same stuff I am thinking about using to replace my carpet but not sure how to get it fitted correctly since as you said, nothing is flat or square. The old carpet I have is misfitted too, so not really a good template to use. You have come up with a great use of the product. Way to Go
keekers is offline   Reply With Quote
Old 06-05-2011, 10:07 PM   #9
John and Jaci's Avatar
Trailer: 1972 Boler American ('The USS NeverSail')
To get it to fit around curves/corners you could use a box cutter and make long slits on the back side of the mat that go about half way through the material. That should Let the back side stretch in the curves but keep the face intact. We are about to that stage of our restore and were thinking to use the same materials. Thought that might work but have not tested it yet. What glue are you using?
John and Jaci | Our furry friends Chief and Scampy
1972 Boler American - The USS NeverSail | 2012 Jeep Wrangler Unlimited
John and Jaci is offline   Reply With Quote
Old 06-05-2011, 11:42 PM   #10
That stuff insulates pretty well, I use it to line the floor and sleep on top of it for tent camping, down to below freezing temperatures. I've gotten packs of that stuff from Costco, $9 for 6 pieces 2'x2' except mine is all dark gray. Not sure if they still carry it any more, but I've also found it at home depot and lowes.
ThomasE is offline   Reply With Quote
Old 06-06-2011, 07:54 AM   #11
Test it first... and after you get the compound corner or curve coered (a tile will comply even without slitting the back) try to match the jigsaw on the surrounding tiles... Mind you, with the shape of the Boler, you will have very few problems laying it nicely as compared to all the relatively sharp curves / steps in the Jubilee shell.
Old 06-06-2011, 07:59 AM   #12
Emily R.'s Avatar
Trailer: 1975 Trillium 13 ft (Fluffer-Nugget)
Love the colours! I'm with you don't paint them.
I also used these same foam tiles (grey) for the flooring in my Trillium...they were easy to install and really nice to stand on. The only downside is when it gets really hot and the sunshines in the door they tend to swell up a bit but nothing serious...it goes back down when it cools down.
Emily R. is offline   Reply With Quote
Old 06-06-2011, 08:09 AM   #13
I haven't started yet, still have to get the old carpet out (probably in pieces). Do you have a recommendation for the glue? Thanks for the hint about only cutting half way thru, it makes sense. I'm not sure how to handle the lump that is the band around the trailer maybe notch out or build up? I'm just about ready to start.
Patti
Old 06-06-2011, 09:37 AM   #14
Daniel V.'s Avatar
Trailer: '74 Trillium 1300
Mix and match might look nice, too?
Example
Daniel V. is offline   Reply With Quote
Guess What I Saw Today Reace General Chat 19 03-17-2009 07:16 PM
guess what happens in two days?? or Joe MacDonald General Chat 11 08-06-2006 10:09 AM
Guess Who Legacy Posts General Chat 9 06-16-2003 04:08 PM
Lost, I guess Legacy Posts General Chat 6 05-16-2003 07:07 PM
