Hanging a papertowel holder, without using screws - Fiberglass RV
Old 04-26-2009, 11:01 AM   #1
Trailer: 2005 16 ft Scamp
I bought a cheap PT holder at Wal Mart, thought I had it up good with double sided tape, but when I put a new role of Brawny on it, down it came. I have a thing about drilling into the fiberglass and just don't want to do it. Any suggestions on how to get that thing to stay put? I even thought of duct tape rolled up over itself, seems really adhesive, but waiting on you guys to try anything else for now.
Monica M is offline   Reply With Quote
Old 04-26-2009, 11:07 AM   #2
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
Use Automotive 2 sided tape
or 3M Double Sided Foam Tape
Old 04-26-2009, 11:47 AM   #3
CindyL's Avatar
Illinois
I bought a paper towel holder that hangs from the front of the silverware drawer. No nails/tape needed. It is held by a bent piece of stainless steel. I got it at Bed Bath and Beyond.
Here is a link: http://www.bedbathandbeyond.com/product.as...mp;SKU=14028315
They do have a couple of cheaper styles too that hang the towels in a similar way. This one, though, drops, so that towels are less in the way.
CindyL
1988 Bigfoot Silver Cloud, "The Egg Carton"
CindyL is offline   Reply With Quote
Old 04-26-2009, 12:27 PM   #4
Raya's Avatar
Or, there are paper towel holders with suction cups on them. I've seen photos of that used on an Oliver.
Keep in mind that some high-tack tapes can be nearly as hard to remove as it would be to patch a hole (which isn't too terribly hard actually), but they do hold well. 3M Command adhesive (removable) now has some hooks that will hold up to 7 pounds or so - you might be able to utilize the adhesive strip from one of those (depending on how the holder mounts and the leverage factor). Doubled up duct tape definitely won't work.
Raya
Old 04-26-2009, 12:32 PM   #5
Doug Mager's Avatar
Trailer: 1975 13 ft Trillium
....there is a product out there called Miracle Putty (I think its called). Its one of those 'as seen on T.V.' (??) advertized by Billy Maze???
It looks like it might work, but the idea of automotive double sided tape sounds better and easier to work with. This tape is w i d e l y used to adhere trim pieces to auto bodys and I'm sure it has many other used.
I doubt very much that rolling duc tape over onto itself would grip to any thing too much, a roll of towel alone is fairly weighty ....then factor in the weight of the holder itself...
Old 04-26-2009, 03:22 PM   #6
william russell's Avatar
Monica...if you decide on the automotive double sided tape, check with a body shop repair guy and see if they will give you a packet (single application) of the adhesive enhancer. Using this along with the automobile double sided tape will do the job. If you use just the tape it will come loose if your trailer gets to hot.
william russell is offline   Reply With Quote
Old 04-26-2009, 03:29 PM   #7
Monica,
I have the same aversion to drilling as you do, and use velcro and suction cups wherever possible.
After two unsuccessful attempts, I found a lightweight plastic (white) towel holder similar to Cindy L's, but the bar that contacts the bottom of the cabinet is longer. (I think it was at Lowe's....)
Velcro has worked for six months and about 7,000 miles so far.
I think the key was, the base that attached to the bottom of the cabinet was primarily level and smooth, as opposed the the previous two holders (one broke while attaching...) that had a lot of indentations and little level surface for "grip".
Old 04-26-2009, 09:20 PM   #8
Tom U's Avatar
Trailer: Fiber Stream 16 ft
Most double sided tapes should work. The Automotive or 3M Foam are best. The most important thing, though, is to make sure the surface is absolutely free of grease and dirt. A wipe down with rubbing alcohol after a Dawn wash down might be in order. Make sure it is absolutely dry before taping.
Good luck.
Tom - '79 Fiber Stream
There is no such thing as an all black cat.
Tom U is offline   Reply With Quote
What are these screws for? Ricky 4 Problem Solving | Owners Helping Owners 11 12-14-2010 11:24 AM
Hanging Tiebacks for the curtains Paul Richter Modifications, Alterations and Updates 9 06-23-2010 06:18 PM
Left hanging... yvonne Care and Feeding of Molded Fiberglass Trailers 3 06-12-2008 06:26 PM
Hanging storage Don Soulsby Modifications, Alterations and Updates 9 05-09-2007 06:39 PM
12 Volt Hanging Microwave LeBoutillier Problem Solving | Owners Helping Owners 7 02-10-2006 05:31 PM
