Hanging storage - Fiberglass RV
Old 04-26-2007, 09:30 AM   #1
Don Soulsby's Avatar
Trailer: Trillium 13 ft 1972
I'm not sure if this solution has been preented before. It is a hanging sweater storge unit. Fits perfectly in the tall Trillium cabinet. No alterations required. Best part was that I found it at the second hand store. Great place for "vintage" parts.
Cheers
PS: I hope I did the attachment correct.
Don Soulsby is offline   Reply With Quote
Old 04-26-2007, 09:36 AM   #2
Doug Mager's Avatar
Trailer: 1975 13 ft Trillium
WOW, what a nice fit.
I just bought (and installed) a 'system' from Canadian Tire which has the availability to be added onto. I think its better suited for a residential clothes closet but seems to fit well in the Trilliums closet. The shelves are adjustible too and the feet (expandable) press down ward onto the closet floor
Old 04-27-2007, 07:38 AM   #3
ericmarlo's Avatar
Trailer: '77 Triple E Surfside
Hi Doug,
Did you buy some piececes from the Extend-It closet system at Cdn. Tire ? I was looking at that just yesterday.
Wondering how it might fit.
When you do the install - could you post pics ?
Thanks,
Eric
ericmarlo is offline   Reply With Quote
Old 04-27-2007, 09:31 AM   #4
Doug Mager's Avatar
Since I'm in the midst of splashing paint all over the place in there (pictures pending), I have 'loosely' hung the unit in place. It looks good.
The unit consists of a pair of legs with adjustable feet. Each leg is in 3 pieces. Because of the shorter height in the trailer closet, I needed only 2 pieces per leg and even at that I had to cut 1 and 3/4 inch off the lower part of the leg to get it to fit in the closet!
I had also purchased one of the 'under the shelf' pull out drawers but had to return it cause it was too wide to work through the closet door opening. The shelves because they are made of rod shaped material, can also double as a drying rack for dish towels, etc. I have only purchased 2 shelves (they are fully adjustable width wise AND side to side ....for levelness(?)) and a pair of (sold in boxes of 2) hangers. They can be used to hang a variety of things AND they come in 3 different configurations including a tie rack (remember these things are designed for a household) LOL!!
The shelving unit I had in its place consisted of a couple of painted scrap pieces of plywood, just setting in there, nothing solidly constructed.
I'll try and post some pix a little later this week(end).
A l'il HEADS UP:
These units are on sale this week so better go back n scoop some up while on sale, you can always return them after IF you decide you don't like'em, LOL
Old 04-27-2007, 11:54 AM   #5
ericmarlo's Avatar
A l'il HEADS UP:
Great info - Thanks - Pics when done would be super.
I've measured my closet on my SurfSide to have a depth of about 17 inches - and width to be about 16 1/2 wide. Both of those measurements are a bit on the small side as I wanted to make sure I had some room to work with. I too saw the sliding drawer and that's what has my wife intrigued. Our closet has a closet bar or rod across the top so I think I could simply attched the vertical poles to that and go from there. hmm?
Old 04-27-2007, 06:26 PM   #6
Doug Mager's Avatar
Yes the unit attaches simply with a spring type clamp to the inside rod. The two legs (one on either side and each in 3 pieces) have expandable feet on the bottom to be screwed down to help stabalize the rack. The soles of the feet have a sticky pad (if you want/need it) to further anchor the unit. Its grey in color, lucky for us, it mstches our decor!!!
The Trilliums closet, I think, is smaller than yours and in ours the closet door is larger than the actual opening in the f'glass for the closet. This is the measurement (width of the opening) you should go by IF you decide to go this way.
IF the drawer won't open inside the closet, it becomes useless.
Old 05-08-2007, 10:17 AM   #7
ericmarlo's Avatar
Hi Doug,
Any chance you were able to do your install of your Canadian Tire closet organizer and post pics ?
How do you like it ?
Old 05-08-2007, 10:08 PM   #8
Doug Mager's Avatar
[attachment=9644:attachm
ent]Here's a little tease, LOL I don't know how to post too many at a time so I may have to do multiple posts.... There's even a shot of my new led lights installed under the cabinet with first coat of white paint on the backsplach!!!
Old 05-08-2007, 10:29 PM   #9
ericmarlo's Avatar
[quote]
Attachment 7738
Attachment 7739
GREAT Pics - Thank you so much! I like that closet idea and the LED lights - fancy !
Old 05-09-2007, 06:39 PM   #10
Doug Mager's Avatar
<span style="font-size:24pt;line-height:100%">10Q !</span>
Hanging Tiebacks for the curtains Paul Richter Modifications, Alterations and Updates 9 06-23-2010 06:18 PM
Hanging items on walls of Scamp karen lm Problem Solving | Owners Helping Owners 9 10-23-2009 07:18 AM
Hanging curtains in the Boler kevin61 Modifications, Alterations and Updates 2 07-16-2009 11:34 AM
Left hanging... yvonne Care and Feeding of Molded Fiberglass Trailers 3 06-12-2008 06:26 PM
12 Volt Hanging Microwave LeBoutillier Problem Solving | Owners Helping Owners 7 02-10-2006 06:31 PM
» Trailer Showcase
Dottie
Loulou
1991 Bigfoot
tbp
