Hanging Tiebacks for the curtains - Fiberglass RV
Old 06-13-2010, 09:35 AM   #1
Paul Richter's Avatar
Trailer: Trillium 1971 13 ft
Thumbs up
Hi there everyone, I was wanting to hang tie backs on the ensolite & purchased some 3M command hooks but they didn't stick too well. What have others used?? Your ideas &/or suggestions would be great!!
Thanks,
Paul "The Nascar Rig"
http://community.webshots.com/user/p...host=community
Paul Richter is offline   Reply With Quote
Old 06-13-2010, 09:45 AM   #2
Why not sew the tie backs to the far edge of the curtains... push the curtains as far back from the window as the curtain rod will allow, then wrap the tie back around the curtain. I've used this method successfully when the tie back has velcro on it... it' wraps tightly. YMMV
Old 06-13-2010, 11:11 AM   #3
Chester Taje's Avatar
When I had my Boler I made a slight cut in insolite and then glued in a plastic hook type thing onto the fg and then used it for curtains and blinds. I never had a problem.
Old 06-13-2010, 12:50 PM   #4
Sandra Lair's Avatar
Trailer: 1982 Scamp 13 ft
Drapery hooks (the kind used in pleated drapes) work perfectly. Just stick the pointed end down into the ensolite. I sewed small plastic rings onto the tiebacks to hang the tiebacks on the drapery hooks. The best thing is that if you ever want to remove them, the hole closes up. I use the hooks to hang other things too. Cheap & easy & works great!
Sandra
Sandra Lair is offline   Reply With Quote
Old 06-13-2010, 06:31 PM   #5
sugermc's Avatar
Trailer: 1983 13 ft Scamp and 1985 13 ft Scamp
not being the domestic goddess ( my friends have stated that the only domestic quality I have is that I live in a house!) I just used spring clothes pins, push the curtains open, and then just clip on the rod.
sugermc is offline   Reply With Quote
Old 06-13-2010, 09:25 PM   #6
Trailer: Trillium 4500
With my Trillium, this location is backed by plywood. As they said in the seventies, "screw at will!"
Scott H is offline   Reply With Quote
Old 06-13-2010, 09:49 PM   #7
Joy A's Avatar
I took a screw out of the window frames. I ran the screw through the edge of the curtain, then through tie back and then screwed it back into the frame from where it came.
You could run the screw just through the tie back if you desire.
Joy A. & Lily
and "Puff", too
No. Ca. Sierra Foothills
Old 06-14-2010, 08:07 PM   #8
Vickie B.'s Avatar
Trailer: 1988 Perris Pacer ('Bean') / 2015 Ford F-150, 2017 Winnebago UltraLite 27BHSS
Nebraska
Hey sugarmc--I do the same thing! I painted mine blue and brown to match the curtains!
1988 Perris Pacer
2010 Honda Ridgeline
2013 Winnebago Minnie 2101FBS
Vickie B. is offline   Reply With Quote
Old 06-23-2010, 05:18 PM   #9
Sandra
Thanks everyone for your suggestions!!
Old 06-23-2010, 06:18 PM   #10
shane n's Avatar
I used a piece of flat aluminum stock cut to proper length and screwed to the window frame with a threaded "well nut", rubber bushing for the tie back to hook to. Total cost from home deep hole $ 3.00
well nut
shane n is offline   Reply With Quote
Hanging curtains in the Boler kevin61 Modifications, Alterations and Updates 2 07-16-2009 11:34 AM
Left hanging... yvonne Care and Feeding of Molded Fiberglass Trailers 3 06-12-2008 06:26 PM
Hanging storage Don Soulsby Modifications, Alterations and Updates 9 05-09-2007 06:39 PM
scamp door - anybody try hanging it on the left? lenny247 Problem Solving | Owners Helping Owners 15 06-13-2006 07:32 AM
12 Volt Hanging Microwave LeBoutillier Problem Solving | Owners Helping Owners 7 02-10-2006 06:31 PM
