Has anyone modified Scamp 13' front potty & closet into bunk - Fiberglass RV
Old 07-14-2019, 08:05 AM   #1
We purchased a 2001 13' Scamp last year, with a porta potti room, vertical fiberglass divider, and two stacked closets in the front of the trailer. We still want to keep the potti option depending on the trip, but also are considering building a removable platform single bunk to run across the front by cutting a hole in the fiberglass divider and replacing the potti door with a curtain. I envision a two part platform, main one in the potti room and the foot portion in the closet, with a hinge or something connecting the two. When used, the sleeper would have their lower legs in the closet and torso in the potti room.
Is this crazy? Has anyone attempted? Is the fiberglass divider holding the roof up?
NCW Scamping is offline   Reply With Quote
Old 07-14-2019, 08:25 AM   #2
Since front bunk models lack the bulkhead, Iím sure the shell will be okay without it, but...
A highly idiosyncratic modification like this will decrease resale prospects significantly. I know that everyone expects to keep their trailer forever, but the reality is few actually do.
Iíd look for other ways to accommodate the extra person. Tent? Tow vehicle? Sell this trailer and buy one that has the extra bed(s)?
Just my opinion, of course. Itís your trailer!
Old 07-17-2019, 06:03 PM   #3
Thank for the reply Jon, we bought the trailer for my mom, and I've been tenting on warmer nights instead of bunking with her. I appreciate the insight!
Old 07-18-2019, 09:04 AM   #4
Thatís a tough one. I have never understood the rationale for giving up the whole front sofa/bunk set-up for just an empty room with a porta-potty when there is a perfectly good storage compartment under the sofa (and they make tents for porta-potties if youíre uncomfortable doing the deed in the middle of your kitchen). A complete wet bath- that I understand, though not for me, not in a 13íer.
None of that helps you now. I think a lot depends on whether this arrangement with the two of you is a short-term or long term issue.
If short-term, the tent works in good weather. In cold or wet, two adults can share the small dinette bed more easily by sleeping in opposite directions in separate tapered sleeping bags. More room and doesnít feel quite so... well... intimate.
If long term, you could convert this to the front sofa arrangement. Do it yourself, hire it done, or for best results, take it to Scamp. Alternatively, look for a 13íer with the front bed or a 16íer with both bath and extra bed. If finances allow, buying in the fall and selling in the spring is advantageous price-wise.
Old 07-18-2019, 10:54 AM   #5
Trailer: 77 Scamp 13
I think the front bunk/couch arrangement the couch being anchored to both the floor and the wood rail fiberglassed to the wall make it a structural element. It doesn't support the roof but it does help keep the front rigid and braced at the corners.
Which floor plan is it? That would allow people to more easily visualize what you are describing. I think you are describing layout #2 from here.
https://www.scamptrailers.com/showro...-layout-1.html
What about a low cot running from the potti closet back toward the dinette bed? Like one of these. https://www.amazon.com/MARCHWAY-Ultr...=fsclp_pl_dp_7 Or even a taller one.
Moving the porta-pottie out to one of those small changing bathroom sized tents might be an option if one is using the pottie closet for sleeping.
I'm thinking don't need to sleep inside unless the weather is bad or just stopping for the night to sleep while traveling and don't want to set up tent.
I tend to agree it is an odd modification, one that would appeal to only a small market segment. Unlike say a front couch into a front dinette and bed. That has broader appeal.
I would also say that on trips you want the pottie you would probably "lose" your second bunk. Might be better to focus on a solution that will work well with or without potty in the room.
The alternating of heads and feet at opposite ends does seem to give more room. Would provide a less intimate arrangement. I think I'll still use the front couch as second bed when brother in law and myself go camping! My rule is only one hairy back in the bed is not generally negotiable.
Still if most times you can use a tent and you are both comfortable the opposite ends and tapered sleeping bags could work ok for the few times setting up the tent is not workable. While allowing the potty closet to always be available. The real fight always becomes who gets the outside of the bed.
Of course a lot of older couples would like your arrangement of storage and toilet. Selling your camper might allow you to purchase a different floor plan better suited to your needs. The only problem with the porta-pottie under the couch is the thing is pretty low. If I could squat like that and stand up again I would still be using a tree as a backrest.
Old 07-18-2019, 11:56 AM   #6
Roger, I think itís an early layout 2. Back in 2001 there was no shower option on the standard, just a toilet, but this one apparently has neither- just the bulkhead and an empty privacy room for a porta-potty, with a closet next to it by the door.
Iím vaguely recalling the early bulkheads were wood, not fiberglass. If the dividing wall between the privacy room and the closet is wood, too, the OP might cut a door into the closet which could be opened to create foot room. Without removing a chunk of the bulkhead, though, getting in and out of such a sleeping space would take some dexterity.
As to the small under-seat porta-potty, you can set it on a platform to create a more comfortable height once you pull it out from the compartment.
I suspect the same about the front bench adding support especially at the lower front corner of the door. Thatís an advantage of having Scamp do the mod- they will tie it together properly at that critical junction.
Agree about the ďhairy backsĒ...
Hi all- Raising front bunk for Porta potty mikeh53 Problem Solving | Owners Helping Owners 4 11-23-2017 02:09 PM
Has anyone looked into this? Denece General Chat 9 06-29-2015 02:34 PM
Front rock guard modified to create an awning who has done it? LRS30 Modifications, Alterations and Updates 26 04-20-2013 11:48 AM
Modified Front Dinette seat option Eddie Longest Modifications, Alterations and Updates 1 12-03-2011 08:36 PM
Scamp 19 anyone modified to tow behind an SUV? Wayne Hill Towing, Hitching, Axles and Running Gear 23 04-13-2011 08:47 AM
