Help with tail lights - Fiberglass RV
Old 09-09-2014, 06:14 PM   #1
Trailer: 1979 Burro 13ft
Arkansas
I'm restoring a 79 Burro 13. I was checking the trailer lights today and everything looked good except for one tail light; small round red lens on passenger side about eye level. Popped off lens, touched the bulb and it came on, then off......loose conection. I took bulb out, tried to tighten the spring metal bulb holder, then ....pop. No tail lights or running lights.
Must have blown a fuse. Don't know where to start looking. All the other trailer lights still ok. Tow vehicle is Nissan Xterra with aftermarket hitch and flat four connector. The tail lights on Xterra are ok. Don't think there are any fuses in Burro. Where would the fuses leading to the trailer cable likely be? Any suggestions?
davb is offline   Reply With Quote
Old 09-09-2014, 07:13 PM   #2
Trailer: 2010 Scamp 16
You might have an inline fuse (little plastic barrel) on the wiring in the trailer or going to the trailer plug.
Might look like this:
http://www.boatelectricals.co.uk/ima...ginal/1340.jpg
or be a flat black block like this:
http://www.hondagrom.net/forums/atta...psac120ede.jpg
Might have some sort of tow package on your Xterra that has a fuse for the trailer plug as part of the Xterra fuse panel, could check the owners manual.
Old 09-09-2014, 07:17 PM   #3
mszabo's Avatar
Trailer: U-Haul VT16
Change the bulb?
Old 09-09-2014, 07:21 PM   #4
Look closely at the Xterra fuse block. I have relays and fuses for trailer lights. There shouldn't be any fuses in the Burro for the running, tail lights, or brake lights. However, a used trailer could have anything.
Old 09-09-2014, 07:47 PM   #5
Exacts same thing happened with my Tacoma. It was a fuse in the Tacoma. Check under the hood.
light, lights, tail lights
Brake Lights, Turn signal lights, marker lights, oh my! glamourpets Problem Solving | Owners Helping Owners 19 01-03-2013 10:10 AM
U haul ct13 help with tail lights Becky B Problem Solving | Owners Helping Owners 13 08-13-2012 07:59 PM
Where to find 4.5" x 8.5" LED tail lights? Cory Lewis Problem Solving | Owners Helping Owners 2 07-21-2009 09:52 AM
LED lights in Original light sockets - tail lights Cam A Modifications, Alterations and Updates 75 02-15-2009 11:54 PM
New Tail Lights - Help! Sitah Problem Solving | Owners Helping Owners 13 07-12-2006 10:43 AM
