Help with trillium exterior! - Fiberglass RV
Old 10-03-2014, 05:57 AM   #1
Trailer: 1975 Trillium 1300
New Jersey
I have a 1975 trillium 1300 with the standard beige gelcote exterior. I have been doing a lot of web surfing and cannot come to a complete decision on what to do with the exterior, so maybe you guys can give me some advice. I know there is no bringing the original gelcote back to a shiny finish, I tried on a test spot and was unsuccessful. The overall outside looks ok, so I was thinking about just applying the zep wet look floor finish over it to make it look shiney, but I know that will magnify any and all imperfections, OR should I paint it then gloss. I know there really is no coming back from the decision I make so I want to be positive before I start, what would you guys suggest?
slipknotfan67 is offline   Reply With Quote
Old 10-03-2014, 06:12 AM   #2
Wetsand the entire trailer with 600 -800 grit sandpaper ,touch up spots that can't be removed with as close to color as you can get ,then use zep sealer and finish with zep high gloss and it will turn out beautifully. Don't paint unless absolutely nessasary or you want a different color .
Mikmay is offline   Reply With Quote
Old 10-03-2014, 08:36 AM   #3
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
Matt, you can go back. Zep floor finish can be removed with Zep floor wax stripper. I read once on a posting from a long time ago, that the car wash setting for engine cleaner will also remove the Zep.
Dave & Paula
Old 10-03-2014, 10:15 AM   #4
David Tilston's Avatar
Zep Wet Look strips off easy. Give that a try first. Be sure your trailer is CLEAN first though.
Old 10-03-2014, 10:38 AM   #5
Trailer: 2010 Escape 17B
This person had just done a beautiful job on their Trillium's exterior.
I spent the weekend polishing the Trillium
kootenaigirl is offline   Reply With Quote
Old 10-03-2014, 03:13 PM   #6
Trailer: 1977 Trillium 4500 (previously a 1978 Trillium 4500, Rpod 171 and Surveyor SV251)
Nova Scotia
Doh - you beat me too it kootenaigirl, lol.
The fibreglass certainly can be brought back to life! However it takes a lot of work with the right tools to get the oxidation off and a nice shine back. Any of these miracle coatings or floor polishes will give a temporary improvement but they don't remove the underlying oxidation.
77 Trillium 4500
Phil 4500 is offline   Reply With Quote
Old 10-03-2014, 03:18 PM   #7
New Jersey
Thank you for your replies, I knew you could strip the floor finish but I didn't know if the stripper would be too harsh on the surface, but you all have pretty much made up my mind, I will wets and it and then apply the zep over the gel coat providing I don't burn through it lol.
trillium
exterior access hatch and exterior shower aimeelightsey General Chat 36 10-06-2012 03:15 PM
Need help with exterior 110 power outlet install Carol H Electrical | Charging, Systems, Solar and Generators 25 08-20-2012 12:33 PM
Exterior paint match for 1978 Trillium Jo R. Problem Solving | Owners Helping Owners 10 11-02-2011 07:37 PM
Trillium exterior access doors Rick G Modifications, Alterations and Updates 9 05-23-2011 02:09 AM
Trillium Exterior Window Strip Krysti Peck Problem Solving | Owners Helping Owners 4 05-13-2007 06:32 PM
» Trailer Showcase
Babie
Naomi Payne
Alice
Mr.Stu
