07-22-2013, 01:06 PM
Trailer: 1976 Trillium 1300; Invertec Falcon 190 class b rv
Hitch Mod to tow and carry 2 bikes
One of the problems that we just encountered when we got our '76 Trilly was how to carry 2 bikes and tow our Trilly at the same time. We already had a Swagman 2 bike 2" hitch bike rack and a single bike hitch rack. We didn't like the idea of trying to carry 2 bikes on rvs rear ladder because we were afraid we might bend the ladder with the wt of the bikes, nor did we want to carry the bikes inside the Trilly or on the rear of the Trilly.
Harbor Freight sells a dual 2" receiver that fits inside a 2" receiver which I purchased and tried out yesterday. With a 20% off coupon and buying it in OR where there is no sales tax made it a deal.
The only problem was the bike rack 2" receiver insert stuck out beyond the ball and had bolts underneath that blocked access to the ball. The fix was to push the bike rack receiver insert all the way in and drill a new 5/8" hole in the bike rack receiver insert to hold it in place. We tried it out with our 2 mountain bikes and it worked!
You will notice that we are also using a straight 2" ball receiver insert for towing in the lower half of the twin hitch receiver. We preferred this ball because there was no nut at the bottom of the ball to catch on the ground. The ball had to be filed down 1/16" to smoothly accommodate the Trilly's coupler.
Hope someone else can make use of something like this.
07-22-2013, 09:24 PM
Trailer: 1984 19' scamp
Kansas
I would really recommend you get a different brand of that setup. I've bought plenty if things from Horrible Fright, but I wouldn't use that.
I buy the hitch extenders from there (same thing, without the top part), because its the cheapest way to make my own receiver hitches for whatever. HOWEVER, I always have to fully remove any old weld from the tube. I have never successfully welded into their welds. They are almost always very dirty, and very porous. I have no issues welding to the actual steel, but those welds are junk. I would never trust them to hold even a bouncing bike rack over time. That weld from the transition between what's in your receiver, and the tube the drawbar is in is very suspect.
07-22-2013, 09:48 PM
Harbor Freight dual receiver weld problems
Thank you for your feedback .
Given this worse case scenario, the good news is that we are only going to be using this dual set-up with a bike rack for 1 hr each time we make a trip to the WA coast because the trailer and bikes are being stored on the Coast and its a 30 minutes to our campsite each way on paved city streets.
For this light use, I think we will be ok, but I will inspect the welds on each trip. If a problem should develop, I would take the pieces to a local welder who recently did upgrades on the "76 Trilly frame.
Others planning to use a similar setup may want to consider other options for these components as you said.
Thanks again.
07-22-2013, 10:19 PM
I have been using HF inserts for years including the dual insert'
I picked up a Reese at a yard sale last year and it's identical to the HF draw bar.
A great deal of my towing is in unimproved roads and I have never had a problem,
I Imagine many American suppliers use Chinese products.
HF electrical products and things with many moving interior parts are not the greatest.
07-22-2013, 10:25 PM
Kansas
You might keep getting lucky. Some runs might be ok, too. Looking at a painted hitch isn't going to tell you the quality of it, or that they're the same.
With our light trailers, the flaw may never show up. Personally, I would rather spend the few extra $$$ on one from a reputable company, or have somebody grind out the old weld (completely, even a few remnants of old weld screwed up new ones), and redo it.
07-22-2013, 11:14 PM
Harbor Freight dual receiver ? problem welds
Jared
Looking at the part again, I definitely see your point about the potential weakness of vertical connection of the 2 receivers. At least, the hitch ball is mounted to the lower receiver.
For extra security, one could try mounting a metal plate on both sides, using the top and bottom 5/8" bolts to secure the plate. That is something I could do myself.
Re-welding the unit would admittedly be the best option and the one you suggested.
If another welding project were to need attention, I would let them re-weld this part , too.
Thanks again for the heads-up.
07-22-2013, 11:18 PM
Harbor Freight Welds
Perry,
Thank you for sharing your experience with this particular HF product. It is reassuring to hear you haven't had any problems with it.
07-23-2013, 06:09 AM
George; heres my opinion. I have one of those dual receiver things but generally don't use it. Got mine from Northern Tool. One problem is that it moves the ball farther back and changes the tongue weight and stress on the car's hitch because of the leverage principal. It's not the same as having a longer tongue. I have the identical or very similar Swagman rack. You can eliminate those bottom bolts by welding a 5/8 nut on a flat piece of steel, insert it inside the rack tube, and use a 5/8 bolt instead of a pin to hold the rack tight to the receiver. I've adapted this rack to fit on the tongue of our teardrop, and use it on the rear of our Uhaul. If you go with a receiver on the rear of the trailer [many opinions on this] it has to be very sturdy because again of leverage of bikes bouncing back there. I've seen a couple racks break off, and had one of mine bend. Any rear receiver that I have built is attached to three points, usually the bumper and two cross members. I like the Swagman rack, but plan on modifying it some.
07-23-2013, 06:33 AM
From a mechanical/leverage point of view that is a very risky set up.
Sorry to be negative. Just thinking about safety.
07-23-2013, 07:13 AM
What you have done is cut your towing capacity in half by extending it out that far. Saving a few $$ is not worth causing an accident. Your tongue weight is now doubled what it was with the shorter set up. Double duty hitches are for non towing uses.
Jim
Never in doubt, often wrong
07-23-2013, 05:27 PM
My post #8 has an error in it. I use a 5/8 bolt to hold the rack tight in the receiver, and a 1/2" bolt to hold the sliding wheel loop assembly tight to the 2" base tube. By doing this I can eliminate those two bottom stiffener bolts.
07-23-2013, 10:36 PM
Thank you for all your advice and warnings. I have been listening and will be extremelyobservant and careful on the 30 min in town trip tomorrow. For the 2 hr + trip home at the end of the summer, I won't use this dual receiver setup for towing the Trilly.
07-24-2013, 07:27 AM
Most accidents happen within 15 minutes of home, hope you beat that statistic!!
Jim
07-24-2013, 04:25 PM
I use a double receiver extension like that on our motorhome, to move the bike rack out (needed for the bike handlebars to clear the rear of the body) and up (for better clearance to slopes or in dips). I don't tow with it, and would not tow a trailer with it. I have considered flat-towing a car with it, but that would involve no vertical hitch load.
I assume the Harbor Freight unit is their Haul-Master Dual Hitch Extender - Item#69881.
Mine is from Princess Auto: Power Fist Class III/IV Dual Hitch Receiver Extension - SKU: 8353211. I have no opinion of the quality of mine, let alone the quality compared to the Harbor Freight unit, but I don't see any obvious visible problems. It could, of course, be junk.
I'm still not sure what this means. It looks like it might mean that the trailer has a 1-7/8" coupler, and that 1/16" was filed off of the surface of a 2" ball (reducing it by 1/8" in diameter) to the fit the coupler. I sincerely hope this is not what was done, but I can't think of a less disturbing but more likely explanation.
If the ball is at the correct height for the trailer's coupler, and yet it is in danger of hitting the ground, the ball is much too far behind the tug's axle... not surprising, given the big extension beyond the receiver, which in turn is probably far behind the axle in what I understand to be a Class B motorhome (which likely has a long van body with lots of rear overhang).
07-24-2013, 05:46 PM
Brian; I took the filing down the ball to mean that there was not enough clearance between the top of the ball and the bottom of the bike rack for the trailer coupler to fit in, and by filing down only the top of the ball he could then get the coupler on the ball. Just my opinion on what was done.
07-24-2013, 06:47 PM
That would be less disturbing, but it doesn't look like - after the bike rack mod - any of the rack is directly above the ball. That visible loop in the photo is one of the bike wheel supports, well away from the ball but incidentally lined up with the camera position.
07-24-2013, 07:06 PM
I have the same rack so know how the wheel loops are set up. Even enlarging the photo I can't tell just where the rack base tube ends up, could be close enough to interfere with the coupler. One of those things you have to be there to see. OP probably wishes he never started this thread, but unintentional hazards do need to be pointed out. I used one of those double hitch things once, and that was with our teardrop that only weighs 650 lb. It sounded like a good idea but decided it wasn't, haven't used it again. I'm on my 3rd bike rack, and various mounting versions, and still not totally satisfied, but I'm getting close!!
07-24-2013, 08:04 PM
The dual receiver worked fine on our 30 min trip with the E-250 pulling the '76 Trilly 1300. There were no problems whatsoever. There were some challenges for the system, like driving on a gravel parking lot with turns at the self-storage site, going 45 mph on a paved city road and going up a steep hill at the rv campsite.The bike rack and 2 mountain bikes survived the 2.5 hr trip to the trailer site as well.The Trilly stayed level at the hitch, too.
I would attribute this success to my set of circumstances (E-250 tow vehicle and a light trailer ) which were favorable for this application. This is not to say this setup would work well and safely for others.
Given the input from this discussion, one would have to say the prevailing opinion was that this system is not recommended for towing a trailer and carrying bikes.
07-25-2013, 11:22 AM
Just interested, what did you have done to your frame, any pics.
This is what I did to carry my 2 bikes. It is only temporary as the previous owner cut the bumper and spare off and relocated the bumper to closer to the shell. I want the spare where it is supposed to be. I'll move the bumper back, mount a new receiver and put the spare back where it's supposed to be, new stabilizer jacks would be nice too.
07-25-2013, 12:48 PM
'76 Trilly Frame Weld Upgrades
Doug,
Your Trilly looks very nice.
The bike rack you set up certainly is one solution to carrying 2 bikes that would get around the objections of all those who have weighed in on the double receiver option. I didn't go this rear bike rack route as I already had a cargo rack welded on to the rear of the frame, was afraid of weighing down the rear of the trailer and wasn't sure if the Trilly frame would support it. That is why I went with the front dual receiver.
A local welder welded two 2"H X 12"L X 1/4" steel plates, short side of the plate end to end, covering 2' of the outer frame, on each front side of the frame where it curves to form the tongue. One plate covers the curve where there is a bolt on the underside securing the shell. The two plates are welded together on one end and all around the edges. It wasn't possible to make the plate all one piece because of both the bend at the front and the rise of the frame in the front, but it has got to be better than what I had before. I primed the steel and then painted it black like the rest of the frame.
The welder also spot welded ( 2" weld on each joint ) all the frame pieces where they came together on the underside of the frame which before didn't look like they had much attachment. I was amazed at what a nice job he did and without damaging the fiberglass underside or front.
