Holding tank gauges - Page 2 - Fiberglass RV
Old 06-04-2013, 05:03 PM   #15
lpk49's Avatar
Trailer: 2007 casita freedom deluxe-2013 tacoma
New Hampshire
this has a lot of info...calgon, etc...but i guess it is sorta off-topic here so i will go there if i have more questions...thx for help
http://www.fiberglassrv.com/forums/f...ank-51452.html
lpk49 is offline   Reply With Quote
Old 06-04-2013, 11:01 PM   #16
Brian B-P's Avatar
the Garnet SeeLevel gauges $100 with 3 sensors-they attach to tank exterior, no holes
Which specific model is this, Jim? "3 sensors" could mean three level points on one tank, but I think it is three tanks.
Originally Posted by tractors1 View Post
Externally attached tank sensors work by capacitance; when the level of stuff gets up to one of the sensors it turns on a light/led, so they're usually discrete levels (1/4.1/2/,3/4, and Full) that are displayed...
Usually, yes, but at least some of Garnet's products - such as the Model 709-A - SeeLeveL II - have continuous strip sensors: the sensor runs the height of the tank (and can be trimmed shorter if required), and the system determines a continuous level (displayed in % full), not just three switch points.
(The product documentation also mentions propane level - that one is not capacitance-based, it is driven by the resistor-type sensor on the float gauge of a typical built-in motorhome tank)
holding tank leak Karalyn Problem Solving | Owners Helping Owners 6 02-24-2013 04:42 PM
Portable Holding Tank R&SGove Problem Solving | Owners Helping Owners 2 06-18-2008 08:58 AM
Holding Tank Chemicals Pete Dumbleton Problem Solving | Owners Helping Owners 10 01-17-2008 05:42 PM
holding Tank Oders Legacy Posts Modifications, Alterations and Updates 10 07-21-2003 04:17 AM
holding tank antifreeze? Legacy Posts Problem Solving | Owners Helping Owners 6 02-17-2003 10:43 AM
