Honda EU2000i installation - Fiberglass RV
Old 07-08-2003, 09:02 PM   #1
Ready to travel.
<img src=http://www.fiberglassrv.com/board/uploads/3f0b82a30c36901 Honda ready to travel 500.jpg/>
Both the Honda generator and propane bottle are mounted between the frame members.
<img src=http://www.fiberglassrv.com/board/uploads/3f0b82c68b2a802 Honda 500.jpg/>
The Honda is held in place with an automotive safety belt. So pop the safety belt buckle and the Honda can be set aside.
<img src=http://www.fiberglassrv.com/board/uploads/3f0b832fb98d103 Honda safety belt 500.jpg/>
The Hondas feet have a recessed 3/4" diameter area. A bolt with a stack of washers positions each foot.
<img src=http://www.fiberglassrv.com/board/uploads/3f0b83a8975ef05 Honda feet guide 500.jpg/>
The propane bottle has an 'easy out' clamp arrangement. The quick release spring loaded clamp is an old boat transom clamp. Pop it off, the tank tilts enough to slip out from under the clamp on the opposite side.
<img src=http://www.fiberglassrv.com/board/uploads/3f0b83e599cff07 Honda tank clamp 500.jpg/>
A 10ga cord plugs in to the Honda and the other end is fed thru the floor of the trailer where the trailer cord stores, and plugs in to the cord. When using shore power, unplug this connection and string out the trailer cord.
The modified plastic propane cover fits over the generator. Held down with velcro tabs and a screen installed on the generator exhaust side so the generator can run with the cover in place.
<img src=http://www.fiberglassrv.com/board/uploads/3f0b84db1d4d306 Honda screen cover 500.jpg/>
Old 07-08-2003, 09:12 PM   #2
PineConeDon,
Very, very nicely done.
As it's mounted solidly to the frame, is there much sound transmission into the trailer while the generator is running?
Old 07-09-2003, 01:53 AM   #3
Very nice, PCD
Old 07-09-2003, 07:35 AM   #4
Good Job
Looks SLICK!
Old 07-09-2003, 09:12 AM   #5
Orginally posted by Bill Abbay
* * * * * * PineConeDon,
Bill:
The Hondas rubber feet are positioned by the 'washer stack' but it isn't mounted solidly to the frame. FWIW, on the first try, I had the washer stack too high so that the Honda was sitting directly on the bolt heads (not the feet) and yes, it did vibrate! Removing 2 washers made all the difference. While running the AC, the compressor will shake, but the vibration in the trailer is not noticeable. What is noticeable is the exhaust being so near the entry where you're likely to set out chairs. For this reason I made it easy to set off in order to point the exhaust away from the trailer. :)
<img src=http://www.fiberglassrv.com/board/uploads/3f0c30c2a87fb09 Honda set off plugged in 500.jpg/>
Old 07-09-2003, 01:30 PM   #6
honda mounting
:wub YES,YES,GREAT IMPROVMENT OVER WHAT I HAD DONE,BUT----- WHERE IS THE GAS CAN????? WILL YOU CARE IF I COPY THIS SETUP? I WONDER HOW IT CAN BE IMPROVED ON????:bh
AC installation John Hedden Care and Feeding of Molded Fiberglass Trailers 5 12-13-2014 05:00 AM
Honda EU2000i Generator For Sale Roland Takayama Classified Archives 1 02-03-2010 10:02 AM
EU2000i Generator John W Simmons Care and Feeding of Molded Fiberglass Trailers 14 02-01-2007 05:23 PM
Escape Trailer and Honda EU2000i Generator Test Thane Care and Feeding of Molded Fiberglass Trailers 12 10-25-2006 12:20 AM
AC installation Ellen S. Modifications, Alterations and Updates 0 12-31-1969 07:00 PM
