Ready to travel.
<img src=http://www.fiberglassrv.com/board/uploads/3f0b82a30c36901 Honda ready to travel 500.jpg/>
Both the Honda
generator and
propane bottle are mounted between the frame members.
<img src=http://www.fiberglassrv.com/board/uploads/3f0b82c68b2a802 Honda 500.jpg/>
The Honda is held in place with an automotive safety belt. So pop the safety belt buckle and the Honda can be set aside.
<img src=http://www.fiberglassrv.com/board/uploads/3f0b832fb98d103 Honda safety belt 500.jpg/>
The Hondas feet have a recessed 3/4" diameter area. A bolt with a stack of washers positions each foot.
<img src=http://www.fiberglassrv.com/board/uploads/3f0b83a8975ef05 Honda feet guide 500.jpg/>
The
propane bottle has an 'easy out' clamp arrangement. The quick release spring loaded clamp is an old boat transom clamp. Pop it off, the tank tilts enough to slip out from under the clamp on the opposite side.
<img src=http://www.fiberglassrv.com/board/uploads/3f0b83e599cff07 Honda tank clamp 500.jpg/>
A 10ga cord plugs in to the Honda and the other end is fed thru the floor of the trailer where the trailer cord stores, and plugs in to the cord. When using shore power, unplug this connection and string out the trailer cord.
The modified plastic
propane cover fits over the
generator. Held down with velcro tabs and a screen installed on the
generator exhaust side so the generator can run with the cover in place.
<img src=http://www.fiberglassrv.com/board/uploads/3f0b84db1d4d306 Honda screen cover 500.jpg/>
