How can I mount these stablizer jacks? - Page 2 - Fiberglass RV
Old 08-19-2012, 10:02 AM   #15
Tim Wood's Avatar
Trailer: Class B for now
NY
I did mine very much the same way as Floyd did his, worked great on my Scamp 13 that I use to have. You can crank them up enough to change a tire if need be.
Old 09-23-2012, 10:56 AM   #16
Pomfritz's Avatar
Name: Gary & Sonja
Trailer: 1989 Bigfoot B17G
Do you only need a set on the rear? Does the tongue jack act as a stabilizer in the front?
Pomfritz is offline   Reply With Quote
Old 09-23-2012, 11:03 AM   #17
cpaharley2008's Avatar
The tongue jack is not a stabilizer, it levels the trailer. Stabilizers are needed both front and rear on a trailer and used after you have the trailer level.
Old 09-23-2012, 11:50 AM   #18
Fran L's Avatar
Name: Fran L and Dave W
Trailer: 2008 Escape 5.0
New Mexico
On the 16' Scamp we used the BAL levelers on the back and did not use the Scamp standard stablizers on the back at all. On the front we didn't use anything other than the front tongue jack. I have never seen any other stabilizers on the front of a Scamp 13 or 16. Maybe it is needed on the longer bumper pull trailers like the Escape 19. We do have front landing gear on the Scamp 5er.
Fran
Fran L is offline   Reply With Quote
Old 03-11-2013, 08:54 PM   #19
Trailer: 1978 Trillium 4500
Finally got my jacks installed. Here's a few picts of the final results.
I had them welded to the first angle iron crossbar behind the bumper. Since this cross bar did not present a flat face at the bottom of the frame, they welded some additional angle iron onto the first, and then welded the jacks below that.
Cost was $150, including the painting over the welds, (not including the price of the jacks).
Cheers
--Fred and Natalie
1978 Trillium 4500 "Bernerwagon"
freddo411 is offline   Reply With Quote
Old 03-12-2013, 05:29 AM   #20
Ian G.'s Avatar
You will love the jacks, I have them on my Boler and set-up is now so easy and fast.
Old 03-12-2013, 06:43 AM   #21
Tim Wood's Avatar
NY
Good job well done. They sure make things easier and more stable too.
Old 03-12-2013, 10:41 AM   #22
Ian:
I checked out your build thread again ... you've got the strongest frame on the planet!
Cheers
--Fred and Natalie
Old 03-12-2013, 12:00 PM   #23
Ian G.'s Avatar
Originally Posted by freddo411 View Post
Ian:
I checkout your build thread again ... you've got the strongest frame on the planet!
Thanks Fred, with the jacks down it does not move at all
Considering the strength of the frame with larger 2000 lb axle and brakes it weighs less that 100 lbs more.
Old 03-12-2013, 07:29 PM   #24
GREAT solution Fred ... I'm green with envy
Old 03-12-2013, 10:53 PM   #25
Night Sailor's Avatar
Connecticut
Well done! That was a smart thing to do.
How many jacks? Greybeard Towing, Hitching, Axles and Running Gear 20 11-20-2011 09:02 PM
Bottle Jacks vs. Scissor Jacks Jane P. Towing, Hitching, Axles and Running Gear 21 02-26-2011 07:17 PM
stablizer jacks thomas kaz Problem Solving | Owners Helping Owners 1 05-19-2009 08:14 AM
leveling jacks and storage jacks Ricky 4 Problem Solving | Owners Helping Owners 1 07-28-2008 10:29 AM
do i really need jacks Lori-Ann Towing, Hitching, Axles and Running Gear 7 08-20-2006 09:31 PM
