How can I mount these stablizer jacks? - Fiberglass RV
Old 05-29-2012, 10:45 AM   #1
Trailer: 1978 Trillium 4500
I purchased a pair of these for the rear of my Trillium:
BAL 20" Light Trailer Stabilizer Jacks - 2 Pack - Other - Stabilizer & Leveling Jacks - Jacks & Levelers
I'm looking for a way to mount them that does not "hang" below the existing frame, as the frame has only about 9inches of clearence, and is likely to "drag" going over low pot holes.
These jacks require side access to operate the screw to make them go up an down.
Ideas:
* weld on a bar on top and inside the box frame for mounting. Drill a hole thru the existing side member for screw access
Cheers
--Fred and Natalie
1978 Trillium 4500 "Bernerwagon"
freddo411 is offline   Reply With Quote
Old 05-29-2012, 12:02 PM   #2
IllAnnoy
Ideas:
One easy way to get minimal clearance would be to cut one ear off of the end of the stabilizer,then place a length of mild steel angle along the frame member recessed enough to allow the tip of the screw to clear the bottom of the frame with the stabilizer attached to the angle.
That would give minimal clearance without frame modification.
I have the larger (full frame member) version of ball stabilizers on my 13 Scamp and I have no problem with clearance in the seven years since they've been installed.
There is something called "angle of departure"...
Take a straight edge and place it from under your rear bumper to the bottom of your tire. If the jacks fit above that line on the frame, they should be fine as it relates to most obstacles.
Those you have will work better, the further forward they are placed(up to a couple of feet)... you could even add another crossmember to locate them where you want them.
Look here....
Old 05-29-2012, 02:09 PM   #3
Trailer: Uhaul CT-13
Ohio
Mine were bolted on one end and welded to the bottom of the bumper on the other, not sure what was used to weld them as the bumper I think is aluminum and the stabilizers are steel.
Panoz77 is offline   Reply With Quote
Old 05-29-2012, 07:31 PM   #4
Doug Arthurs's Avatar
Your bumper must be steel. That's a pretty poor looking weld by the way. There is almost no penetration into either the bumper or the jack. I guess since the load is pushing up its no big deal but if your trailer ever did a little forward roll while on the jack I would expect that weld to break free or crack. You might want to look at the weld on the other end and see if it's better. I hope however welded that isn't doing other more critical parts.
Sorry about the hijack. Now back to your regularly scheduled program.
Doug Arthurs is offline   Reply With Quote
Old 05-29-2012, 09:00 PM   #5
dylanear's Avatar
Trailer: 2001 Scamp 13'
My scamp rear legs are bolted to the bumper.
At time mine do not lock solid. Perhaps because they are old, seems to do it more when cold. But I have considered finding an alternative and your selection looks like it would be solid and allow for minute, precise adjustments.
dylanear is offline   Reply With Quote
Old 05-29-2012, 09:02 PM   #6
dylanear's Avatar
Look here....
Those look very solid, what kind of legs/stabilizers are those?
Old 05-29-2012, 10:29 PM   #7
IllAnnoy
They are Bal Stabilizers but they form their own crossmember and are heavier duty, there are two different heights available.
you can see details and read my review here...
BAL Deluxe Telescopic Stabilizing Jacks - JCWhitney
Old 05-30-2012, 06:11 AM   #8
Raz
Raz's Avatar
Vermont
On the "new" Trilliums they have two pieces of angle iron welded; one to the main frame member and one to a cross member. Raz
Old 08-18-2012, 10:15 AM   #9
Pomfritz's Avatar
Name: Gary & Sonja
Trailer: 1989 Bigfoot B17G
Floyd
When we got our trailer we received sets of scissor jacks by BAL. similar to what you have. I'd like to mount them on the frame. What did you modify per your review.
Thanks
Gary
Pomfritz is offline   Reply With Quote
Old 08-18-2012, 10:32 AM   #10
Fran L's Avatar
Name: Fran L and Dave W
Trailer: 2008 Escape 5.0
New Mexico
We have the same BAL Leveler that Floyd posted. We love it. We ordered the 20" version and, for our 16' Scamp, we had to trim some of the cross piece or it would have been too wide for the Scamp. Not hard to do. Then we bolted it on to the frame underneath. As Floyd said, measure your 'angle of departure' and you should find a suitable location. When we upgraded to a 19' Scamp we took the BAL Leveler off and had it welded to the 19' Scamp. We were having some welding done for the axle anyway so we just had the welder do the BAL also.
It is quite convenient and the best part is that you have a full range of heights instead of dealing with incremental heights on the Scamp factory stabilizer legs.
Fran in NM
Fran L is offline   Reply With Quote
Old 08-18-2012, 11:15 AM   #11
Peter Steckhan's Avatar
Trailer: 71 Boler
Saskatchewan
I have those same levelers mounted on my boler. When I had the frame rebuilt, I had a cross member welded in and the levelers are welded to that. With them positioned at this height, the screw handle just clears the body. I'm not sure what the Trillium frame looks like or how low the body is on the outside, but on my boler I would have had to drill a hole in the body for the handle if the leveler was mounted any higher.
Peter Steckhan is offline   Reply With Quote
Old 08-18-2012, 02:19 PM   #12
mmeyer's Avatar
Trailer: U-Haul VT
Indiana
I used unistrut and a Square UBolt to mount Atwoods on the front of my U Haul. It will work for any type of support. Unistrut has some special nuts that fit inside the cross section which allow for infinite adjustment as to position. I used metal screws designed to hold metal siding on steel buildings to attach the ends to the trailer perimeter frame. No welding was needed. the Unistrut was flexed to fit on the bottom of the frame and the top of the main tube of the frame.all the bearing weight is directed through the outer frame and results in a pretty secure setup. picts attached.
Michael J.
mmeyer is offline   Reply With Quote
Old 08-18-2012, 02:53 PM   #13
cpaharley2008's Avatar
How about this mounting system?
SaveAJack.com
Old 08-19-2012, 09:51 AM   #14
Pomfritz's Avatar
Name: Gary & Sonja
I think I'd like to weld them on if I can get enough clearance. I've got to carry them anyways and would like 4 less things to store.
How many jacks? Greybeard Towing, Hitching, Axles and Running Gear 20 11-20-2011 09:02 PM
Bottle Jacks vs. Scissor Jacks Jane P. Towing, Hitching, Axles and Running Gear 21 02-26-2011 07:17 PM
stablizer jacks thomas kaz Problem Solving | Owners Helping Owners 1 05-19-2009 08:14 AM
leveling jacks and storage jacks Ricky 4 Problem Solving | Owners Helping Owners 1 07-28-2008 10:29 AM
do i really need jacks Lori-Ann Towing, Hitching, Axles and Running Gear 7 08-20-2006 09:31 PM
