How do I fix broken corner of the door - Fiberglass RV
Old 03-02-2016, 10:06 PM   #1
Trailer: 13' Boler
The bottom corner of my 70's 13' Boler is chipped. The bottom 2-3" on the one corner is broken off.
How can i fix this?
davis is offline   Reply With Quote
Old 03-02-2016, 10:59 PM   #2
Dennis mn's Avatar
It looks to be a rather straightforward repair, build up with glass cloth and resin, then file and sand to the proper shape. There must be "how to videos" on U-Tube to give you some basic knowledge. I think the trickiest part is to get the first layer of glass to conform to the proper shape until the resin cures. I would tape a piece of cardboard as a piece of cereal box, or similar to the inside of the door lip. Layup the first piece of cloth and resin over the armature, then after the resin cures, do a bit of shaping. Repeat until you get the desired thickness.
2019 Airstream 19 Foot, pulled by a 2014 Nissan Frontier Pro4-X Crew Cab.
Dennis mn is offline   Reply With Quote
Old 03-03-2016, 09:56 AM   #3
Trailer: Still Looking
Alabama
If you can get to both sides of the area you can 1) Rough up the area on the inside and taper back to sound glass and beyond 2) Tape a piece of waxed Formica to the outside. Use a piece large enough so it will take on the curvature of the door. 3) Apply epoxy resin to the Formica, then fiberglass finishing cloth (only barely overlapping the broken edge 4) Continue with mat and roving, wetting out each with epoxy and overlapping the joint more with each layer 5) Stop this process only after the thickness is greater than the surrounding area 6) Allow to dry overnight 7) Remove Formica 8) Sand/fill/prime as needed down to 220 grit 9) Paint or spray gel coat with a Preval sprayer (if your unit is still gel coat)
Bullington is offline   Reply With Quote
Old 03-03-2016, 10:42 AM   #4
Trailer: Fleetwood Prowler
Alabama
Nice description.
SteveSmith is offline   Reply With Quote
Ventura door leaking top left corner- baffled how to fix Cheyanna83 Problem Solving | Owners Helping Owners 5 05-23-2015 05:00 PM
Trillium Corner Cubbys For Sale Thom T Classified Archives 10 11-20-2010 08:37 PM
Cracked and Broken Fiberglass Fix it Yourself Highway68 Care and Feeding of Molded Fiberglass Trailers 16 03-20-2010 09:46 AM
Scamp Square Corner Windows Steve R General Chat 3 09-14-2007 06:56 PM
The Holidays are Around the Corner! General Chat 0 01-01-1970 12:00 AM
