How do i set up a battery system? - Fiberglass RV
Old 05-09-2012, 12:50 PM   #1
Trailer: Havasu
We have recently gutting everything out of out 10ft trailer and I would like to set it up with a battery system. The trailer currently has a breaker set up so it can be hooked up at a site however when we are not at a hookup site I would still like to have power. I am very green here so here are my questions;
The battery is DC so I need an inverter to run the lights, outlets and mini fridge when I am not at a hookup site, correct? Do you recommend a particular inverter?
A converter is to charge the battery, correct? Can it only be used by plugging it into a 120V system, so in other words in order for me to charge my batteries I need and outlet?
How long will two 6v batteries last running just a fridge and a light here and there, should it last 2-3 nights before needing to be re-charged?
How can I make the batteries last longer, get more and daisy chain them together?
What is the best battery to get? And would you recommend two 6V or two 12V?
Also does anyone have a diagram on how to hook the batteries up?
Thank you!
zoshia is offline   Reply With Quote
Old 05-09-2012, 01:13 PM   #2
Thomas G.'s Avatar
If all the lights, etc are 110 volts AC, then you would need an inverter to run them off the battery. You may need a true sine wave converter sized to meet the starting load of the refrigerator
It will also run 12 volt accessories from 110 volts AC input
Can it only be used by plugging it into a 120V system, so in other words in order for me to charge my batteries I need an outlet?
Yes, unless you use a solar panel or wire your tow vehicle to charge the battery
A 110 volt AC refrigerator running off an inverter takes a lot of power. Rabbit has a thread here discussing such a system http://www.fiberglassrv.com/forums/f...far-51781.html
Yes. 6 volt batteries would have be wired in series to create a 12 volt pair, then additional 6 volt batteries would have to be also wired in series to create another 12 volt pair, with the pairs then wired in parallel. But remember that the batteries are very heavy - it quickly becomes impractical.
Two 6 volt golf cart batteries work great.
RV Batteries Wiring Diagrams
Thank you!
You are welcome
Old 05-16-2012, 01:06 PM   #3
Trailer: Havasu
Thank you! Very helpful
Old 05-16-2012, 02:04 PM   #4
cpaharley2008's Avatar
Go here for your answers, part 1 and part 2
The 12volt Side of Life (Part 1)
battery
time to add a battery system, could use input please adriemel83 Problem Solving | Owners Helping Owners 20 08-14-2011 08:31 AM
Charging Battery and running battery lights when plugged in Nor_Cal_Todd Problem Solving | Owners Helping Owners 2 08-25-2010 01:44 PM
New battery- what type for future solar system? LizP Problem Solving | Owners Helping Owners 15 02-26-2009 06:30 AM
Dual Battery System ???? Gerry Problem Solving | Owners Helping Owners 6 10-18-2006 04:31 AM
12v system work just on battery McClure Problem Solving | Owners Helping Owners 9 08-21-2006 08:50 PM
