How to polish/fix ZEP wet look FF? - Fiberglass RV
Old 05-08-2013, 06:55 PM   #1
chse's Avatar
Trailer: 13' Scamp
After giving my scamp a stripe I started the ZEP treatment. Unfortunately I started with a cheap microfiber cloth which had lots of microfibers.... not attached to the cloth. There is an area on the roof and side which is quite uneven from the fibers. Did someone ever try to slightly sand the floor finish- will I have to strip it and start over in this area? I was really careful around the (many) rivets but there is some ugly build-up between some that are close together, again can I sand this or carefully rub with ammonia window cleaner?
Here is a picture of the progress so far (3 coats) in the storage place I am using- lots of old, cool, rotten cars there.
chse is offline   Reply With Quote
Old 05-08-2013, 07:21 PM   #2
cpaharley2008's Avatar
try to reapply with a new cloth, it may remove the dried stuff.
That looks like a neat storage place, tight quarters though. some sort of basement in an older building?
Old 05-08-2013, 07:38 PM   #3
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
I'm with Jim- try again with a (prewashed) rag...I think Zep acts as its own solvent and the fresh will dissolve the old. Just keep changing rags and hopefully you can mop the fibers/excess off.
Francesca
Old 05-08-2013, 08:04 PM   #4
chse's Avatar
Trailer: 13' Scamp
I tried, after I noticed the fibers I changed to a more leather like cloth, the fibers sticked to the 1st layer, though.
Yes the storage is in an old factory upstairs is storage lockers downstairs garage. The camper just fits through the door. I normally push it by hand to its space so no problem with tight corners.
Old 05-08-2013, 08:14 PM   #5
With any "cloth" used to apply a final finish, wash/dry, wash/dry, wash/dry. I have no other opinion other than to say... is it good enough for a 10 yard look? Maybe you're too close to the project. If it's sealed and done... IMHO GO CAMPING. It's not about looking perfect (even brand new from the factory finishes aren't perfect), but is it good enough for you to get out and camp "this season."
In years past, I've camped in tents where holes with sealed with duck tape, my Scamp exterior was less than stellar clean... but one thing I've always made was memories. Do not delay due to a less than perfect trailer finish. The one thing you can NEVER get back is time....
Old 05-08-2013, 08:32 PM   #6
chse's Avatar
Trailer: 13' Scamp
I hear you - I already cut back a lot on the list (who needs new cabinet doors...). All it really needs else is new tires- we booked a campground in 2 weeks! But don't you also get trailer fix addiction (TFA!) if you see all the nicely remodeled ones here?
Old 05-08-2013, 08:39 PM   #7
Never, ever compare your knowledge.. skills, abilities and budget to someone else. As is said... walk a mile in their shoes. Truly making memories is all about YOU. Before too long someone else's beautifully finished trailer fades to the background when you realize you're out and having a terrific time.
You're not "them" and they aren't "you." Who cares? GO CAMPING!
Old 05-09-2013, 09:46 PM   #8
Perry J's Avatar
Trailer: 16' Casita
I did the same thing on my first Zep job.
I ended up using 400 grit wet/dry sand paper and doing a light wet/dry sanding.
I have a neighbor with a whole herd of little kids.
I talked her out of some old diapers and they didn't leave any lint.
Old 05-11-2013, 05:58 PM   #9
chse's Avatar
Trailer: 13' Scamp
I ended up sanding the area carefully with wet 320 paper. I think it took the fibers off but I needed 3 layers to cover the sanding scratches, so striping it would have worked as well.
After taking it out in the sunlight most of the faults disappeared, the shop lights in the garage apparently made them show much more.
Washing the cloth before application is a very good idea.
Old 05-11-2013, 08:57 PM   #10
Saskatchewan
Wow Perry - I recall my mother talking about guys who could charm nuns out of their knickers - but you - you charm neighbour ladies out of their diapers! ;-)
Sorry - couldn't resist!
Hazel in Sk is offline   Reply With Quote
Using Zep to restore oxidized fiberglass jgeoffw Care and Feeding of Molded Fiberglass Trailers 35 06-27-2016 08:20 AM
Polish over 100% acrylic dmcclure Problem Solving | Owners Helping Owners 7 09-05-2011 05:17 PM
Clear Coat Polish Darwin Maring General Chat 0 04-29-2010 05:32 PM
Fiberglass Cleaner and Polish Chester Taje Care and Feeding of Molded Fiberglass Trailers 27 08-07-2007 09:15 AM
How to clean & polish exterior? Legacy Posts Care and Feeding of Molded Fiberglass Trailers 3 10-21-2002 10:18 AM
