How to relocate spare tire - Fiberglass RV
Old 09-10-2016, 06:32 PM   #1
Trailer: scamp
Has anyone relocated the spare tire from the rear of 16' Scamp camper to underneath the tongue?
kmeats is offline   Reply With Quote
Old 09-10-2016, 06:45 PM   #2
sokhapkin's Avatar
SW Florida
It is possible, but why do you want it? What is the reason for the mod?
Sergey
www.callwithus.com
Old 09-10-2016, 07:50 PM   #3
Trailer: scamp
How to locate spare tire
I need the weight off the rear to mount a bike rack and the extra tongue weight to balance load.
Old 09-11-2016, 02:13 AM   #4
Borrego Dave's Avatar
Trailer: Casita SD17 2006
That move may equal out the weight pretty good Keith.
Old 09-11-2016, 03:05 PM   #5
Name: Wayne & Barbara
Trailer: Parkliner
Iowa
I would be concerned about losing ground clearance.
that would also be under the battery where acid could spill and do damage to the rim and tire.
some folks have made a bike rack in front above the battery and LP tanks.
It's a better place for bikes. On the rear they can block the tail lights.
Old 09-11-2016, 08:34 PM   #6
Trailer: scamp
Thanks for the input! ground clearance does concern me and damage to the tire
Old 09-12-2016, 01:16 AM   #7
Don't think you'll ever see a clearance problem with the tire mounted under the A frame, the angle points, axle-ball-axle, on these molded TT's are to short for much real change. If you should hit it mounted there, well you'd have to be off roading or curb hopping. My last class A had 12' between the rear axle and hitch, that one would drag just going through a road drainage swale if I had to cross it at a 90* angle. I wouldn't be worried about battery acid dripping either. I've only had one battery leak to the extent of dripping in over 120 vehicles and don't think it would hurt the tire anyway, may be wrong but I've never had it hurt rubber that it contacted. If you wanted to give it a try, cut a 2x4 for the top to span the frame, then through bolt the spare up. Have someone watch as you try different angles. I think you'll be fine with the change.
Old 09-25-2016, 07:46 AM   #8
Trailer: 84 16' Casita
I have done this mod and like it very much. So far I haven't had it hit anything.
Jeff in OC is offline   Reply With Quote
Signs For your Spare Tire Cover Al V Problem Solving | Owners Helping Owners 11 03-15-2009 12:28 AM
Spare Tire Cover Terry F Care and Feeding of Molded Fiberglass Trailers 17 09-05-2006 09:11 PM
Spare Tire Rack Legacy Posts Problem Solving | Owners Helping Owners 20 07-01-2003 10:41 AM
Spare Tire Rack Legacy Posts Modifications, Alterations and Updates 5 05-15-2003 07:39 AM
Spare tire cover General Chat 0 12-31-1969 07:00 PM
