How to restore the curve in Scamp door - Fiberglass RV
Old 11-23-2017, 01:23 PM   #1
Trailer: Scamp 13"
Idaho
I'm almost there in getting my door to fit. However there is a significant gap-about 3/4 in.- on the bottom outside corner of the door. It's just a bit much to expect a gasket to fill. So, I'm wondering how to get the curve to draw in. Do I need to tear into it?
Also, I tried to search for previous posts about this issue (assume I'm not the only one to deal with this) and I can't seem to navigate successfully the search option...suggestions? what's the trick?
PilotPica is offline   Reply With Quote
Old 11-23-2017, 02:20 PM   #2
IllAnnoy
Two points
If it has an aluminum threshhold it is adjustable.
I use a 3/4" solid closed cell foam for the bottom gasket and the new closed cell door gasket from Scamp for the door.
The 3/4" foam has worked well since installed 13 years ago.
It is also available in 1" which would work as well.
The last two pictures show first the threshold gasket and then the door gasket.
List of seals to restore old style scamp jaloused windows DannyH Problem Solving | Owners Helping Owners 24 02-04-2016 02:59 PM
Scamp restore questions serendavid Towing, Hitching, Axles and Running Gear 12 02-04-2013 03:28 PM
78 Scamp restore XL milkjug Modifications, Alterations and Updates 7 01-31-2012 09:45 PM
Scamp Entry Door Curve? scott p Problem Solving | Owners Helping Owners 8 06-01-2010 01:41 PM
1980 Scamp Restore Lawrence W Modifications, Alterations and Updates 1 05-12-2010 09:57 AM
