Hunter Compact-II Ideas, Updates, Bathroom Removal etc. - Fiberglass RV
Old 07-16-2014, 04:41 PM   #1
After much discussion it became apparent that the built in bathroom in our Hunter Compact-II represented a lot of wasted space that being used less than 5% of the time and could be put to better use. As a result I tore out the existing toilet and holding tank and replace it with a Dometic SeaLand porta-potty on the sliding track. The entire area above the new porta potty became a huge clothes and general storage closet. The original clothes closet (it was only about 12" wide) became a shelved storage area.
That and a few other projects have made the Hunter much more friendly to live in.
Here is a link to about 40 pics of these recent updates. Although the pics are in no particular order, you can see the following.
Hunter Mods 2014 Photos by advocateone | Photobucket
1. Change-out of original (and still working) Dometic RM23 refrigerator for later and larger Dometic 2193 that was salvaged out of a wrecked Scamper slide-in camper for $40.
2. Addition of a slide out food prep/snack table under the refrigerator.
3. Removal of the original Monogram pedestal toilet and holding tank, and replacement with a Dometic SeaLand porta-potty mounted on a set of heavy duty slides.
4. Construction of a large closet and storage area in the upper area of the original bathroom.
5. Conversion of the original clothes closet to a shelved storage area.
Feel free to browse the other files in that account
Old 07-17-2014, 08:49 AM   #2
Deleted duplicate pics in link....
Old 07-18-2014, 09:26 AM   #3
Bobbie Mayer's Avatar
Trailer: 2011 Escape 15A
I'm curious about the heavy-duty slides for the PortaPotti. What are they mounted to and what keeps the weight of a person on the pot from ripping that mount out?
Old 07-18-2014, 10:19 AM   #4
The slides are rated at 150 lbs each fully extended. They are attached to sheet steel mounting brackets, with tabs on the slides and the mounting brackets, as well as a couple of mounting bolts. The mounting brackets themselves are an inverted "U" shape with mounting flanges and there are total of four carriage bolts, extending through the now 1 1/2" of flooring, at the back edge, with large steel fender washers inder the floor to distribute the load.
Just in case: I also made a small block of redwood than can be slide under the front of the porta-potty tray to support it when extended. I will review if there is a need for this after more testing.
Compact/Compact Jr./Hunter, etc. owners POLL JenPB General Chat 22 03-17-2014 09:31 PM
Egg Camper storage, etc, etc. rgrugg General Chat 1 05-23-2011 03:22 PM
71 Boler 13' Floor Removal/ Shell removal mikeandmadi Problem Solving | Owners Helping Owners 1 05-23-2011 10:28 AM
16' bathroom model Casita, Scamp, etc. in Northwest Richard Bertram Wanted: Molded Fiberglass Travel Trailers 1 06-15-2008 02:59 PM
Travels with a Donkey (or Burro, Boler, etc. etc.) Des Nolan Camping, Campout Reports 6 01-27-2007 09:38 PM
