I have a 12v fan I want to run on shore power - Fiberglass RV
Old 08-31-2014, 02:36 PM   #1
Washington, D.C.
Novice question for my 1975 Trillium 1300.
I am installing a Maxxfan, the instructions say attach to 12v power source. Can I just splice it into the wires above my light fixture above the sink? The light runs off shore power, 110v, so will it still work on the fan or am I about to blow something up here?
Dietrich is offline   Reply With Quote
Old 08-31-2014, 02:51 PM   #2
sokhapkin's Avatar
SW Florida
No, you can't. 110v of shore power will burn out 12v motor in the fan.
Sergey
www.callwithus.com
Old 08-31-2014, 03:15 PM   #3
Washington, D.C.
Good call, I'll she'll out $20 for a converter.
Old 08-31-2014, 04:26 PM   #4
deryk's Avatar
New Jersey
you don't have any 12 volt lighting in your trillium?
deryk
Old 08-31-2014, 04:40 PM   #5
Washington, D.C.
Not sure, I'll bust out the ohmmeter, most lights only work when I'm plugged in
Old 08-31-2014, 04:42 PM   #6
sokhapkin's Avatar
SW Florida
"most" or "all"? That makes a big difference.
Sergey
www.callwithus.com
Old 08-31-2014, 06:52 PM   #7
deryk's Avatar
New Jersey
Dietrich I think you need to more familiarize yourself with your trailer and its components.
Do you have a 12 volt battery? Is it taking and holding a charge? Check your fuse panel make sure all the fuses are good. Check the light bulbs... typically they are the bayonet style like cars have... unless a prior owner installed led fixtures. You really want to know what is and works on 12 volt. do you have a water tank and pump...does it work? Tapping into the 120 ac line will be a costly mistake.
deryk
Old 08-31-2014, 07:34 PM   #8
Mike Magee's Avatar
Trailer: Li'l Hauley
Most trailers have 12V DC lighting, run off the battery. Household AC current can come in via the power cord to a converter, which recharges the battery. The battery can also (usually) recharge somewhat from the wiring going to the tow vehicle.
If you had 120V AC lights, they would have the household screw-in base just like in your home. This would be unusual.
How to prepare Tofu
Step 2: grill some meat
Old 08-31-2014, 07:57 PM   #9
Trailer: Fiber Stream
Question
I wonder if you already have a converter, but no battery?
That could explain why your existing lights only work when you are plugged in.
Shore-power connector replaces pull-out cord peterh Modifications, Alterations and Updates 72 12-18-2016 11:43 AM
Run both 120 & 12v electrical jimkill Modifications, Alterations and Updates 17 07-31-2013 02:33 PM
76' Surfside - Does the battey charge when shore power is plugged in? dannis Problem Solving | Owners Helping Owners 2 05-26-2012 07:36 AM
A Question About Shore Power Red-Dwarf Problem Solving | Owners Helping Owners 10 03-21-2012 04:20 PM
Converter makes noise when in shore power Tezha Problem Solving | Owners Helping Owners 9 10-13-2010 02:52 PM
