Ice box door issues - Fiberglass RV
Old 08-10-2011, 08:03 PM   #1
Brian E Moon's Avatar
Trailer: 72 Boler 13'
Ice box door issues
My 72 Boler 1300 came with an ice box. The door had issues for the last 25 years and finally the door fell off and I set out to replace the ice box with a fridge. After reading forum posts and pricing out new and used ones I decided to fix it!
Here is the ice box with door off and removed from the Boler.
You can see the only damage is around the flange especially where the door is mounted.
So I decided a 11/2"x1/4" aluminum flange glued to the existing plastic ice box might work. I mitered the corners to 45 degrees and filed down the corners to prevent scratches etc.
Here are the results, it works great, held up under a bumpy road or two and now keeps the beer cold most importantly!
Brian E Moon is offline   Reply With Quote
Old 08-10-2011, 08:13 PM   #2
GOOD for you Brian. Glad it works for your needs.
Old 08-11-2011, 12:37 PM   #3
Trailer: 1977 Scamp 13 ft
Great job! I have seen dozens of those boxes with that same damage. Your repair looks great!
David Morgan is offline   Reply With Quote
Vintage Ice box Erin Smith Classified Archives 1 05-25-2011 12:29 PM
Uhaul ice box door seal Judith Kennedy Problem Solving | Owners Helping Owners 1 10-03-2009 06:39 PM
Ice box in a Scamp 13 joehung Care and Feeding of Molded Fiberglass Trailers 13 10-05-2008 06:55 PM
Ice Box - Where to find? Sandy Gilpin Care and Feeding of Molded Fiberglass Trailers 10 12-09-2005 10:26 PM
