Inexpensive LED lights from IKEA - Fiberglass RV
Old 08-03-2011, 05:12 PM   #1
kevin61's Avatar
Trailer: Two 13 ft Bolers and one 17 ft Boler
I heard about these the other day so I decided to buy a set and attach directly to my 12 volt system. They passed the test so the little trailer will be getting a few. The 17 footer will get about 21 ft. of them.
For those who use shorepower you can leave the transformer on if you like this type of lighting.
LEDBERG Light strip - IKEA
kevin61 is offline   Reply With Quote
Old 08-03-2011, 06:45 PM   #2
Trailer: Uhaul CT-13
Ohio
Interesting, can you join more that 3 strips together? Are they adhesive backed?
Also, I just recently posted a thread with very cheap LED bulbs that I found on ebay, I posted a small review, they are nice and bright and only cost about $4.00 a piece shipped but I don't have a meter to see what they draw, but I'm sure it's pretty low as well.
Panoz77 is offline   Reply With Quote
Old 08-03-2011, 06:48 PM   #3
Tim Wood's Avatar
Trailer: Class B for now
NY
Thanks Kevin, good info.Where can you get these in the US ?
Old 08-03-2011, 07:20 PM   #4
Ohio
Tim, we have IKEA in the US.
http://www.ikea.com/us/en/catalog/pr...?query=ledberg
They are $14.99 in the US.
Old 08-03-2011, 07:39 PM   #5
kevin61's Avatar
these come with little clips but I'm sure they could be glued in place. For these particular lights you can only attach the three pieces. I believe they have other higher priced lights that can make longer strings.
Old 08-04-2011, 05:46 AM   #6
Tim Wood's Avatar
NY
Thankyou
Old 08-04-2011, 08:15 AM   #7
Paul Chet's Avatar
Trailer: Vixen Motor Coach
just a great and most helpful post Kevin. thanks for taking the time to do this. as i have a very similar project in mind and all the parts for (just need to find 2 minutes to rub together!).
i bought the two reading lights ($9.99) and the one flat long one about 22-24" from Ikea too. I also picked up two LED rope lights from Target. they are 15' (yes thats FEET) long but were only $9.99 each! not sure how they add up to Ikea's LEDs in terms of quality - but i have a very similar plan. i found some small plastic gutter that i will be cutting / ripping (length-wise) in half, so it will turn from one square piece, into two U-shaped pieces. then mounting the u-shaped pieces with the open side up 'near' the ceiling with a few inches of clearance overhead and running the LEDs starting from the front and running the perimeter of the interior, terminating into the closet where our electrical is handily located. soffit lighting! i will wall mount several other LEDs for cooking and reading, but this will give a really elegant glow and be nice for dinner inside or relaxing to a movie. the lights cost $20, the plastic channel was $16, once mounted we will either match paint with the interior or even use some kind of razor thin wood veneer. the utility of this project will also offer me a handy channel to run wiring for future projects without having to cut into the wall or ceiling insulation, so its a win-win.
your test and resulting information really helps me with my planning. thanks again for this great post Kevin!
Paul Chet is offline   Reply With Quote
Old 08-04-2011, 08:38 AM   #8
kevin61's Avatar
Glad to hear my post has been helpful. I plan to devise some type of bounce lighting as well and will check out Home Depot for possible solutions as per your "gutter" suggestion.
I just ordered these today for wet locations such as the shower, outside and in the range hood vent. Not sure if they are warm white or cool white but for the price I will take a chance.
3 METRE BOAT FISHING LED LIGHTS WHITE WATERPROOF 12volt | eBay
NOTE: the price is in British Pounds.
As of today 1 GBP = $1.57 Canadian or $1.63 US
Old 08-04-2011, 09:27 AM   #9
Paul Chet's Avatar
those are really nice looking Kevin. i forgot to mention the LED rope i got was from the garden section and also enclosed in a waterproof casing. with 30' of lights i'll have some extra i can cut off or run the extra lights right through the kitchen / bathroom wall and light the bathroom as well. since they are sold as waterproof ... we shall soon find out!
Old 08-04-2011, 09:30 AM   #10
kevin61's Avatar
We don't have any Target stores here yet in my part of Canada but I will have a look at other stores as they may have a similar item as the rope lights.
I notice they are described as electric on the Target website. Do they have a transformer for 12 volt or are they just 110 AC?
Old 08-04-2011, 09:51 AM   #11
Paul Chet's Avatar
yeah, shouldn't be too hard to find. i think they ship if that helps any:
Home Rope String Lights - Clear (15') : Target
Old 08-04-2011, 10:13 AM   #12
Trailer: Two Trillium Jubilees and a Trillium 1300
Send a message via MSN to Bill Reilly
LED Lighting
Kevin
Thanks for the great post on the IKEA lights. I'll certainly pick some up for one or more of the units I'm currently working on.
I found your battery monitor interesting. Could I ask what model it is and where you purchased it. I'm thinking of going all electric in my latest aquisiton and will need similiar device.
Perhaps other members could make suggestions re battery monitors as well.
Bill Reilly
Picton, Ontario
Bill Reilly is offline   Reply With Quote
Old 08-04-2011, 10:40 AM   #13
kevin61's Avatar
The monitor is a Xantrex XBM. It has been replaced with this model I believe.
Battery Chargers | LinkLITE Battery Monitor | Xantrex
You will have to Google a supplier as the place I purchased mine closed down. I did manage to get a new XBM from eBay for the 17 ft. trailer I am working on for about $150. I think my Youtube channel will have videos of the monitor in action
‪kevinhenry61's Channel‬‏ - YouTube
I remove the monitor from the trailer in the winter as the screen may freeze.
Old 08-04-2011, 10:55 AM   #14
Ohio
I tried to mount rope lights around the interior using stick on hooks (same ones from wlamart but mine were 30 footers 14.99), I don't think I let the adhesive on the hooks cure long enough and most of them came loose, but the problem was I had to place the hooks and rope lights at the same time due to fitment issues. Here is a picture from when they were up, it looked great until the following morning, then I spent 4 hours with plastic scrapers and goo gone to remove the adhesive patches stuck to the roof and walls.
lights
LED trailer lights / Non LED lights on tow vehicle Kevin K General Chat 20 11-24-2010 11:05 AM
LED lights Francine P Problem Solving | Owners Helping Owners 12 04-03-2009 09:29 PM
LED lights in Original light sockets - tail lights Cam A Modifications, Alterations and Updates 75 02-15-2009 10:54 PM
LED Lights Dave Mac Problem Solving | Owners Helping Owners 9 07-24-2007 04:44 PM
NEW LED LIGHTS!! Christi V. Modifications, Alterations and Updates 12 05-10-2007 09:10 PM
