Install fantastic fan - Page 2 - Fiberglass RV
Old 07-15-2016, 10:45 AM   #15
When I installed by FF on my Scamp using butyl tape under the flange and snap caps over the screws on the roof. Turned out well. I did add a small bead of Sikaflex 221 around the vent once installed. Worked well.
Only thing I would do differently would be to use a Deluxe Maxxfan rather than a FF. That way you will be able to leave the vent open in the rain without the need for a separate vent cover. Recently installed a Deluxe Maxxfan in my current trailer over the bed area and very happy with it - to me it is a far better system than the deluxe FF with rain sensor/remote etc that was already on the trailer at the other end of it. Find the FF is louder and has a more complicated auto control system & needs to be shut if its raining out.
Old 07-15-2016, 12:42 PM   #16
Raz
Raz's Avatar
Vermont
While the fantastic fan may not have all the conveniences of the Maxx fan, it does have one advantage, a better motor mount. The reason I was installing a new Fantastic fan was that the motor mount on my Maxx fan failed due to torsion caused by the motor spinning. It was 6 years old. Anyone with a ceiling fan can observe the same rotational forces at work. I hope you have better luck. Raz
Fantastic Fan a little bit less fantastic Davie B Problem Solving | Owners Helping Owners 10 05-15-2013 04:25 PM
Fantastic fan flange install Pat C Problem Solving | Owners Helping Owners 8 07-05-2009 09:43 AM
Fantastic Vent vs. Fantastic Fan Ami P Care and Feeding of Molded Fiberglass Trailers 5 06-30-2008 11:33 AM
Fantastic Fan Install - switch to change air flow? Kurt in BC Problem Solving | Owners Helping Owners 29 11-11-2007 04:58 PM
Fantastic Fan install questions TonyL Problem Solving | Owners Helping Owners 18 02-28-2006 06:59 AM
» Trailer Showcase
Fun Gus
psyber_guy
burro
Jody
