Installed electric brakes on my U-Haul VT - Fiberglass RV
Old 10-22-2012, 06:50 PM   #1
Trailer: U Hall VT
I just put new hubs and electric brakes on our VT, I made the hubs to fit the axel, about like Tom did, drilled the backer plates like Kevin did and put 14" tires on it.
Roger Kimble is offline   Reply With Quote
Old 10-22-2012, 07:03 PM   #2
Tim Wood's Avatar
Trailer: Class B for now
NY
Roger, Looks great job well done. And how do you like your new brakes ?
Old 10-22-2012, 07:05 PM   #3
Trailer: U Hall VT
They are better than the old ones, we didn't have any.
Old 10-22-2012, 07:11 PM   #4
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Looks good Roger.
Old 10-22-2012, 08:35 PM   #5
Trailer: U Hall VT
Thank you Tom, it took a little time, but worth every bit of it. It is almost like yours but a little different.
Old 10-23-2012, 07:04 AM   #6
Thomas G.'s Avatar
It is worth noting that you found 14" wheels with enough positive offset to be used on a UHaul. This is a significant discovery and one that I'm sure will help other UHaul owners in the future.
Old 10-23-2012, 07:15 AM   #7
Trailer: U Hall VT
Smile
They have a bolt pattern of 4.5", not the 4.75", most car wheels will not carry the 1600lbs like the trailer rims will, the ones I found will carry 1400lbs my off set is 5.25 .
Old 10-23-2012, 07:49 AM   #8
Thomas G.'s Avatar
Roger, thanks for clarifying that. So, you must have gone with the Lumina hubs to get the 4.5" bolt circle. According to this sketch that I picked up here, the original backset was 4.5". Have you had a chance to measure your clearance to the wheel lip yet? I ended up with about 1".
Old 10-23-2012, 04:57 PM   #9
Trailer: U Hall VT
Smile
The lip to the tire is one inch with my 205x 14's,
My stub axel is 5.75" from my mounting plate, my mounting plate is 3/8" thick
Old 10-24-2012, 07:20 PM   #10
Trailer: U Hall VT
Wired the axel today, got the brake controler installed today
Old 10-28-2012, 06:06 PM   #11
Trailer: U Hall VT
My back space is 5", just checked today, pulled it out to the farm, ajusted the brakes.
I just found out today that Dexter axel is in Fremont Ind.
brakes, u-haul
electric brakes Kenny Strong Problem Solving | Owners Helping Owners 54 04-24-2012 08:53 PM
advice re. electric brakes for U-Haul CT-13 Bridget T Towing, Hitching, Axles and Running Gear 6 06-07-2011 01:22 PM
Electric Brakes Steve Smith Towing, Hitching, Axles and Running Gear 10 08-23-2008 05:36 PM
Electric brakes Greg Janke Towing, Hitching, Axles and Running Gear 11 03-31-2008 11:45 PM
Electric brakes Greg Janke Problem Solving | Owners Helping Owners 0 12-31-1969 07:00 PM
