Installed Microwave Oven in Bigfoot 17CB - Fiberglass RV
Old 08-25-2012, 11:35 AM   #1
Trailer: 1993 Bigfoot 17 ftCB / 2003 Honda Odyssey
I decided to install a microwave oven in my 1993 Bigfoot 17CB to hang down from the upper cabinets to the right of my sink, in an area that is 'relatively' unused and out of the way.
The Bigfoot cabinets are securely mounted and there is a prewire box inside the upper cabinet, so I assume that they did mount them inside the cabinet. This would cause loss of space and be hard to modify back if the microwave needed to be changed or removed.
I decided to hang it below, using 1/4X20 threaded rod and 1"X1/8 flat aluminum strips. With these ovens being so cheap, I spent over half it's value for the pieces to mount it.
I bought:
6' 1/8X1" aluminum straps
4 fender washers
4 nylock nuts
4 acorn dress nuts
6' 1/4X20 threaded rod
1 electrical duplex outlet
1 outlet plate
1 replacement plug (I cut off the plug to feed the wire)
5' 1/4 ID x 3/8 ID poly tubing to dress up the rods
pkg #12 x 1/2 self tapping metal screws
I installed the upper ends of the rods with fender washers on the right and used a 13" alum. strap for the left end to distribute the load to the heavier wood at the front and rear of the cabinet.
The pictures should tell the story pretty well.
Time will tell if it's in the way or gets bounced around enough to pull loose or some other problem.
I did run into several 'glitches' in the installation. I bought the wrong plug for the cable, I pinched a 12V power wire in the cabinet, running hidden between the boards, I misdrilled a self tap mounting hole, BUT, it finally went together OK and I'm pleased with the results.
IF you decide to do something similar, make sure that the cabinets have enough strength, other wise this method could be used for other things too!
Mike
Michael Pupeza is offline   Reply With Quote
Old 08-26-2012, 07:21 AM   #2
kirkman's Avatar
Looks great!
kirkman is offline   Reply With Quote
Old 08-26-2012, 07:34 AM   #3
I use the microwave in my Scamp all the time. If you're like me, you'll enjoy having it handy
bigfoot, microwave
Toaster oven/Microwave/Convection oven Karalyn General Chat 22 02-04-2017 11:45 PM
Microwave or Convection oven? MyronL Camp Cooking, Food & Recipes 10 07-26-2012 07:02 PM
Microwave or Convection Oven pamtoffey Problem Solving | Owners Helping Owners 4 05-30-2010 03:00 PM
Bigfoot 17CB, Installed 2nd Batt, Link 20 tomorrow! Michael Pupeza Modifications, Alterations and Updates 6 06-23-2008 03:28 AM
Toaster oven/Microwave/Convection oven Camp Cooking, Food & Recipes 0 01-01-1970 12:00 AM
» Trailer Showcase
Betty Beach
danio
Moose
Ryaine
