Originally Posted by joneswilder
I'm planning on installing an AC in my
Burro 14. (9kbtu seems best for me in Florida) Rooftop models are too heavy. Window units are noisy and difficult to mount without looking tacky.
My search has been narrowed down to ductless inverter unit mounted on the tongue with inside air handler panel on the wall. My tongue is already cluttered up with
battery and
propane tank. Pros, efficient inverter system, permanent mount. 9kbtu models cost about $500 - $700.
Another option is the Climaterite. Basically a window type unit that is stored in the TV, taken out when you park and hooked up to two flexible duct hoses that mate to small round ports mounted in the wall. Pros, easier to install. Cons, 65 lb(104 for 10kbtu) unit that has to be moved in and out of TV and not inverter. 5kbtu and 10kbtu models $500 and $600 respectively.
