Jim,
The 3-cushion sofa is/was supposed to make access to the under sofa
storage compartments easier (even with the bunk bed configuration
and some stuff/bedding piled on one side or the other) and facilitate
a possible mod to allow the porta-potti to be used, on some trips,
right in the same spot where it normally travels.
The wooden platform previously used to raise the Dometic Sanni-potti
to "facility height" is/was 4" tall and was intended for use in an outdoor
"privacy tent" or in a corner of the "dance floor" inside the
Scamp.
As I'm sure you know, without an adjustable height platform, the most
added height that I could get with the porta-potti in its current spot is
about 2".
Whenever we get a small twinge of 3-foot-itis, it's because we would like
more private indoor OBF (what Dennis Archer calls "onboard facilities")
and more storage space for use on longer journeys.
Moving the porta-potti off of the "dance floor" would also make it easer
to put in a "privacy curtain" between the 54" bed and the porta-potti
space.
Similar to what you did, I had intended to open up that cabinet by
cutting up from the current opening for the porta-potti cabinet door
and then cutting toward the front of the trailer to a spot just aft of
where the sofa back cushion sits. I would then put .5" plywood on
either side of that area to support the fiberglass sofa-bottom fiberglass.
A top lid for that area would also have an attached vertical piece of
plywood which would cover the hole where the old cabinet door was
also and provide support for the lid to that area.
We had a setup like that in our old StarCraft Starmaster 21 (or was it
the Venture?) pop-up tent trailer.
In the pop-up, when the lid was raised (and the attached vertical piece
came up with it), the two pieces of plywood could be secured in the
upright position with a catch mounted on the side of the sink cabinet.
To similarly secure the two pieces of plywood in the Scamp, I had
considered snap attached to cord/cable that could be run around
the top bunk attachment point.
At that point, the porta-potti (
sitting on a 2" raised platform) would be
exposed and could be used right in the spot where it normally is stored.
Although we really like most everything about our Scamp13 L1 with the
54" bed, you do lose a little storage space and the 54" bed does extend
an extra 10" into the "dance floor" space.
On a positive note, the 54" bed and bunk beds recently allowed us to
sleep my wife, myself, and 3 grandkids (two 12year old twins [boy+girl]
and one 10yo girl).
We slept 5 in our Scamp13 with 54" bed
http://www.fiberglassrv.com/forums/f...bed-68650.html
On that same trip, we also registered
25 mpg towing the Scamp at
59 mph. I'm guess it might be difficult to get that same economy
and utility from some of the 16ft trailers. See later segments in the
following thread:
Towing a 16' Scamp with small diesel
http://www.fiberglassrv.com/forums/f...sel-68781.html
Although we want to keep the bunk-beds capability for some trips, there
will often be trips when it is just my wife and I traveling around. Those
would be the trips where it would certainly be nice to be able to use the
porta-potti in its normal storage spot .... especially on nights (or days?)
where there is major thunderstorm going on outside or we are parked
far far away from a bathroom with flush toilets.
With your creativity, I'm sure you could also envision a way of putting a
table-post base of some sort below the porta-potti platform so that we
could maybe occasionally have a front dinette if we really wanted it.
Right now, we sometimes use a fold-flat portable table for meals where
we are just sitting on the front sofa.
In case you hadn't seen them, pictures of our Scamp interior/exterior
can be found in some of the later segments of the following thread:
Scamp Full Size Bed = Smaller Table Size
http://www.fiberglassrv.com/forums/f...ize-65096.html
We have only had our 2014 Scamp since October of 2013 and we are
still learning how to make the best use of the space available to us.
Sorry this rambled a bit .....
We will see how things work out as future trips unfold.
Ray
