Installing brakes - 13' Boler - Page 2 - Fiberglass RV
Old 07-03-2011, 06:19 AM   #15
Trailer: 1977 13' trillium
Nova Scotia
My manual for the 2008 City Golf says...
max. 1321 lbs without trailer brakes
max. 3100 with trailer brakes
We plan to install brakes so I wouldn't consider this marginal - towing a 13' Boler.
Melanie is offline   Reply With Quote
Old 07-03-2011, 07:23 AM   #16
Nova Scotia
update
The trailer we made an offer on, 1977 13' Boler, does have a square flange on the axle with four bolt holes ...so...
Do we need a new hub in order to install brakes?
or
Will the brake drum fit onto the existing hub?
I'm trying to get a sense of the cost involved...
Pictures are appreciated. Thanks.
Melanie
Old 07-03-2011, 09:44 AM   #17
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
Look here Dexter Axle - Trailer Axles and Running Gear Components - Home
Old 07-03-2011, 11:31 AM   #18
Trailer: 13' Boler 1977
Melanie:
If you have the flange there then all you need to buy is the actualy brake components, a guess on cost, would be in the range of $100 per side, plus wiring and brake controller.....
It is a lot less than if the flanges are not there......
A quick search on princess auto and you'll find trailer brakes
pbraunton is offline   Reply With Quote
boler, brakes
Installing new Dexter brakes Carol H Care and Feeding of Molded Fiberglass Trailers 6 04-18-2011 01:59 PM
Brakes for an '83 13' Burro JMS Towing, Hitching, Axles and Running Gear 5 01-17-2011 11:19 PM
Installing electric brakes Rich Morrison Towing, Hitching, Axles and Running Gear 11 11-25-2010 06:10 AM
Electric Brakes on a 13' Boler Erik J Towing, Hitching, Axles and Running Gear 22 03-01-2009 12:57 PM
Installing Boler Plexiglass Windows kevin61 Problem Solving | Owners Helping Owners 1 06-24-2008 08:19 PM
