Installing cutoff valve in toilet water supply line - Page 2 - Fiberglass RV
Old 04-08-2015, 12:38 PM   #15
Fran L's Avatar
Name: Fran L and Dave W
Trailer: 2008 Escape 5.0
New Mexico
You are right the pex stuff is pretty easy to work with.
The nice thing about the Sharkbite fittings (even though they cost more) is that it does not require the crimping tool. Just a little 'ring' device that you use to compress the fitting to allow the pex to pass the 'teeth' of the fitting. You use the same little device to release the fitting and pull the pex out again. The ability to easily remove the fitting was important to us.
Fran L is offline   Reply With Quote
Old 04-08-2015, 07:50 PM   #16
Trailer: 1985 BigFoot G
Mississippi
OK Thank you. I'm going to seal every hole I can find.
Gardnpondr is offline   Reply With Quote
I need help installing toilet. Ed D Plumbing | Systems and Fixtures 39 05-08-2011 10:46 AM
installing propane line for Wave 3 heater April Wilcox Problem Solving | Owners Helping Owners 27 12-22-2008 07:36 PM
Water supply when there's no water supply Dave M Plumbing | Systems and Fixtures 18 06-06-2006 10:00 PM
