Installing engineered flooring - Fiberglass RV
Old 04-08-2009, 11:41 PM   #1
Trailer: 1977 Boler
Looking to install some 1/2 inch engineered oak flooring in my boler over the plywood floors. Is there a mininum thickness required of the sub-floor?
Thanks
RogerH is offline   Reply With Quote
Old 04-08-2009, 11:49 PM   #2
Jim Bennett's Avatar
Roger, as long as the plywood that is down is sound, then you can go right over top. Engineered floors, because they are floating, are actually quite flexible. As long as you don't have more then 1/2" deflection in 4' you should be fine. It is pretty much like using a laminate. Click HERE to see another thread about flooring where I had commented on engineered wood flooring. I plan on doing cork in my trailer when I get it.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 04-08-2009, 11:59 PM   #3
Trailer: 1977 Boler
Thanks for your reply Jim. I was thinking of glueing it down with PL400, do you think this is a wise idea?
Roger
Old 04-09-2009, 12:36 AM   #4
Raya's Avatar
One thought that comes to mind is weight. Unless you are replacing the axle - and assuming it is original - your early Boler axle is probably rated at 1200#. As we were discussing in another thread, that's actually "worth" more than you'd think on an 1100# (plus contents) trailer, because you don't have to count un-sprung weight, but it's still something to consider. I don't know how much the flooring would weight, all-told.
Raya
PS: I'm really looking forward to following along on your restoration.
Old 04-09-2009, 04:36 AM   #5
Don N's Avatar
Trailer: 1978 Boler 1700
I wouldn't think you would want to glue it down as this flooring is designed to be floating?
Don N is offline   Reply With Quote
Old 04-09-2009, 11:48 AM   #6
Gail S.'s Avatar
Trailer: 1973 Bug-eyed Boler
oops - I posted in the wrong forum - Sorry.
Gail S. is offline   Reply With Quote
Flooring JasonWesterman Care and Feeding of Molded Fiberglass Trailers 27 04-07-2010 02:07 PM
Flooring! Karen L. Modifications, Alterations and Updates 1 04-09-2009 10:09 PM
flooring Scott S. Modifications, Alterations and Updates 7 06-04-2008 10:40 AM
Flooring Legacy Posts Modifications, Alterations and Updates 59 01-28-2006 08:15 AM
Flooring Classified Archives 0 01-01-1970 12:00 AM
» Trailer Showcase
Sunny
Rich and Rei
Rucio
jen b
