installing fantastic fan cover on my Casita - Fiberglass RV
Old 05-04-2016, 10:22 AM   #1
yyyyyguy's Avatar
Trailer: 17' Casita SD
Wisconsin
Well it looked easy on the video...then I ran into rivets instead of screws and a 1/2 in of silicone all around the vent, so can I drill out the rivets,cut away the silicone and replace with screws and silicone the heck out of it? Ok wife says I should have had Casita install it...HELP!!
yyyyyguy is offline   Reply With Quote
Old 05-04-2016, 10:36 AM   #2
LOL I had the same unsavory discovery when I put the vent cover on my Scamp. Yes, drill out the rivets (likely only four in the proper location, the rest stay in place).
I used rivets that turned out to be just a bit too long and if you run your hand on the ratfur on the inside roof you can feel them poke just a little. So I would call Casita if I were you, and ask what size to use.
Can't recall if I had to remove any sealant but I did use new sealant under the brackets, in the holes with the rivets, and on top of the brackets.... 5 months and still dry, even with the vent open. Great mod!
Old 05-04-2016, 11:41 AM   #3
Trailer: Escape 5.0 TA
Fan cover
If I remember correctly, the cover attaches to the top edge of the fan not to the Casita. When I installed a cover on my Casita's fan I did not disturb the rivets or silicone that was used to mount and seal the fantastic fan. Consider reading the cover mounting directions. I think there is also a utube video on the install.
starbrightsteve is offline   Reply With Quote
Old 05-05-2016, 05:17 AM   #4
yyyyyguy's Avatar
Wisconsin
You must have the "max-air" which is the one I now wish I would have tried to install...no holes in the skin, thanks though
Old 05-05-2016, 07:45 PM   #5
Trailer: '84 Scamp 13' & 2001 Casita 17' Spirit Deluxe
Arkansas
I installed the Camco cover (from WalMart) over my fantastic fan last summer. The instructions called for using tiny bolts & nuts through the upper shroud/frame of the fantastic fan. That would've entailed 'dropping' the fan a few inches in order to get to the shroud frame & secure the nuts on the bolts. I ended up using 1/2" long #8 pan head sheet metal screws through the shroud to hold the brackets that hold the cover. We've towed the Casita almost 1K miles since with no problems, & leave the fantastic vent open all the time for ventilation. The cover has a screen on the inside of the louvers to keep out insects... I was planning to get a Maxxair cover but found the Camco for much less $$. I'm perfectly satisfied with it up to now, & if it 'went bad' tomorrow I'd still think I got a good deal.
Harvey is offline   Reply With Quote
casita
Installing Fantastic fan on my Burro Martin G. Problem Solving | Owners Helping Owners 10 10-27-2015 11:45 AM
Installing Maxx Air Fan Mate 850 Vent Cover Over Fantastic Fan CampyTime Modifications, Alterations and Updates 7 10-10-2013 10:43 AM
Fantastic Fan a little bit less fantastic Davie B Problem Solving | Owners Helping Owners 10 05-15-2013 04:25 PM
Fantastic Vent vs. Fantastic Fan Ami P Care and Feeding of Molded Fiberglass Trailers 5 06-30-2008 11:33 AM
Installing a Fantastic Fan Tamid Problem Solving | Owners Helping Owners 1 05-29-2007 08:23 PM
