Installing spark ignitors on stove! - Fiberglass RV
Old 06-05-2010, 01:31 PM   #1
Trailer: 1993 Bigfoot 17 ftCB / 2011 Toyota Sienna
Hi,
I thought that some might be interested in how I installed a sparking system for my 4 burner Wedgewood stove in the Bigfoot 17.
I've included, I hope, 4 pictures showing how my install went.
The battery ignitor was an ebay purchase for about $25 and had 4 outputs. I used teflon coated wires to run each output to a ceramic spacer, available in old electronic supply houses, or fleamarkets, or use homemade substitutes. From the top of each spacer I used a piece of stainless steel wire, onto which I slipped a teflon sleeve, stripped from some other teflon coated coax cable wire, and bent to shape to clear the cover yet make a nice spark right in front of a gas outlet in the burners. The positioning of each of these did appear to be fairly critical, in that it took a lot of sparking before the burner would light if it was offset too much. I made sure the wire was below the main flame so it shouldn't scorch too much. I'm not sure how well the SS wire will hold up with the heat, but I also have some chromaloy high temp. wire that I can use if it doesn't work out.
I couldn't get enough clearance inside the stove so I mounted it outside, between the burner knobs and the oven knob. It sticks out a bit, but doesn't look too bad. The oven, however, still has to be lit with a hand ignitor. Boo!
To use the system, I turn on a burner and depress the red button. All 4 burners start sparking and the one I want usually ignites within the first 2 sparks - about 1 a second.
It's not an essential mod., but just another neat one!
Good luck.
Mike .....>
Michael Pupeza is offline   Reply With Quote
Old 06-05-2010, 05:48 PM   #2
Chester Taje's Avatar
That looks pretty good to me. Nice Job.
Old 06-06-2010, 02:15 PM   #3
peterh's Avatar
I did something similar with the 2-burner stove in our Scamp . . . it's a really great and worthwhile mod that we really enjoy having!
I got spark Mike Taylor Modifications, Alterations and Updates 13 03-31-2010 06:59 PM
Installing an alcohol-electric stove --- good idea? E. Graham Problem Solving | Owners Helping Owners 14 09-17-2009 10:33 PM
Installing a Husband Bigfoot Mike Jokes, Stories & Tall Tales 12 03-11-2009 07:15 AM
Installing a refrigerator Gene Hudspeth Problem Solving | Owners Helping Owners 4 08-03-2008 08:48 PM
Installing an alcohol-electric stove --- good idea? E. Graham Modifications, Alterations and Updates 0 12-31-1969 07:00 PM
