Instead of paint - Fiberglass RV
Old 11-13-2010, 04:24 PM   #1
Vicki A.'s Avatar
Trailer: 2014 Escape 5.0 TA
Instead of paint
Instead of paint, has anyone thought of "skinning" you egg?
Wondering if there are any pros or cons vs. painting. what do you all think?
Vicki
Vicki A. is offline   Reply With Quote
Old 11-13-2010, 09:55 PM   #2
Trailer: 74 Boler
What do you mean by "skinning"?
Brian Tin is offline   Reply With Quote
Old 11-14-2010, 08:10 AM   #3
Vicki A.'s Avatar
I guess it's vinyl...like the stuff they put on vehicles for advertisment.
Old 11-14-2010, 08:27 AM   #4
I'm thinking a vinyl coating would be an expensive all over proposition for something fairly easily damaged (rock chips on the front for instance) and question the long term ability to stand up to UVs. If paint is out of the question, maybe follow the lead of those that think Red Max is wonderful stuff?
Old 11-14-2010, 08:29 PM   #5
Gumpit's Avatar
Trailer: 1978 Trillium 4500
Massachusetts
I think if you search auto wrap you will find it. It cost hundreds of doallrs for simple wraps and thousands for the SUV and more difficult ones. For the price you could paint your camper several times at Maaco.... It says it lasts about 5 years or is at least guaranteed for that. But some only last a year. Randy
Gumpit is offline   Reply With Quote
Old 11-18-2010, 09:17 PM   #6
Tom U's Avatar
Trailer: Fiber Stream 16 ft
Take a look at an old vinyl topped Caddy or LTD from the late '70s/early 80s.
Tom - '79 Fiber Stream
There is no such thing as an all black cat.
Tom U is offline   Reply With Quote
Old 11-19-2010, 09:58 AM   #7
Trailer: uhaul 13
Hunterdon County, NJ
Vicki,
FYI Vinyl wraps usually cost the same, if not more than paint jobs, especially when it's a difficult installation like wrapping an egg with 3 axis compound curves. Pat
goosler is offline   Reply With Quote
Old 11-19-2010, 10:12 AM   #8
Vicki A.'s Avatar
Thanks to all for the input... guess I'll get Tillie painted at some point!
Old 12-02-2010, 12:44 PM   #9
Trailer: 84 16 ft Scamp
I've done vinyl tops on several cars, usually because the tops were dented by someone climbing on them or carrying something heavy on top without a proper car top carrier.
It isn't too bad a job, however an industrial upholstery sewing machine is usually needed to seam the material as it is seldom wide enough. Along with this is a bench large enough so the seam comes out perfect and straight.
Where you will be challenged is at the ends where a compound curve exists. Even though the vinyl is quite stretchy, there are limits. You would need to develop and construct "gores" similar to those seen on older Airstreams and Avions, except in sewn vinyl. I'd say you'd have to be pretty good to pull this off and make it look professional.
Probably, paint is a much better strategy.
New paint! Christi V. Modifications, Alterations and Updates 17 02-26-2009 09:55 PM
we may need to paint after all April Wilcox Problem Solving | Owners Helping Owners 5 12-16-2008 10:38 PM
To sand and paint, to paint, or to leave it be...these are the questio JenPB Care and Feeding of Molded Fiberglass Trailers 8 12-07-2008 10:39 AM
Paint ? Christi V. Problem Solving | Owners Helping Owners 6 03-18-2008 07:00 PM
To paint or not to paint andrew ferguson Care and Feeding of Molded Fiberglass Trailers 8 08-14-2007 07:02 PM
